Digital Coax or Fiber Optic cable?
charliez
charliez Posts: 72
Hi guys!
I´m thinking in upgrade my cables. Actually I have a FO cable bought 7 years ago, but wondering if coax is better sounding cable,
What are your thoughts about that?
BRGDS
Post edited by charliez on
  • AndyGwis
    AndyGwis Posts: 3,655
    edited October 2007
    I opted for coaxial for all my digital audio hookups. I think they are very similar in quality, but coaxials are easier to get in and out of the jacks. I went with them for convenience sake.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • jwhitakr
    jwhitakr Posts: 568
    edited October 2007
    I have switched between coax and optical for watching DVDs and also watching HD programming from my cable provider, and did not hear any difference in sound quality. If I were you, I'd spend my money elsewhere on upgrades.
    I would be surprised if anyone responds that one or the other offers better sound quality.
    My HT
    HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
    AVR: Harman Kardon AVR 235
    Video: 80GB PS3, Toshiba HD-XA1 HD DVD
    Fronts: Polk Audio RTi8
    Center: Polk Audio CSi3
    Amp: Emotiva LPA-1
    Surrounds: Polk Audio R150
    Sub: HSU STF-3
    The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
  • engtaz
    engtaz Posts: 7,669
    edited October 2007
    I don't think you will hear the differences but Wires are measured in resistance and fiber optics are measured for cable loss. To me, anytime you reduce your loss if a good thing.
    engtaz
  • jrlouie
    jrlouie Posts: 462
    edited October 2007
    I once heard a person state that they felt a more significant difference could be heard between optical and coax not by the cable, but by the proper implementation of the conversion in the player to the pertaining format that is output (i.e. - light or electrical). So for example, for optical, there is a tiny device in your player that converts the data to light pulses. So if that device and its conversion process is less perfect than say the what gets sent over a coax cable, then that might have a more significant effect. Just something to chew on, I don't know how true it is.
    That being said, I had always used optical on my DVD player until one day I tried coax. In my setup, I felt the coax sounded better.
    As they say.....ya just gotta try.
  • charliez
    charliez Posts: 72
    edited October 2007
    JR, good comment!
  • steveinaz
    steveinaz Posts: 19,545
    edited October 2007
    I found that (assuming the interfaces are good quality) fiber has a very neutral sound, coax less analytical. If you go with Toslink, get a good glass fiber toslink cable--not plastic.
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited October 2007
    You were saying? This forum is full of people with magic ears.:rolleyes:
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited October 2007
    I do not hear the difference i have my computer hooked up via coax and my sirius via fiber and no difference
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • mantis
    mantis Posts: 17,325
    edited October 2007
    There is no audio difference between coax and Optical of the same quality. I have done this test many many times with low end to high end cable. Once the cables are built correctly the extreme high end cables made no difference at all.
    Buy whatever one you want as long as it's a good quality cable.
    Dan
    Dan
  • SolidSqual
    SolidSqual Posts: 5,218
    edited October 2007
    crappy coax sounds better than crappy toslink, but my Signal Cable Coax sounds identical to my Blue Jeans Cable Toslink.
  • Frank Z
    Frank Z Posts: 5,860
    edited October 2007
    mantis wrote: »
    Dan
    Based on your pontification we can then infer that there is no difference between lamp cord and anything costing more that .$50 per foot.
    Schmantis didn't hear a difference so that means there isn't one. More spam from Dan.:rolleyes:
    Is there an difference between the two, only your ears can make make the determinination. Anyone that says otherwise is a buttmunching moron that hasn't got a clue.
    Next topic.
  • mantis
    edited October 2007
    Frank Z wrote: »
    Next topic.
    At what point where we talking about speaker wire? Did you even read the opening post?
    So *edit for poor choice in words*what makes you anywhere near anykind of expert? I didn't realize you have been in the field for the last 9 years.
    Edit off, your reply is one of a complete Edit
    Dan
  • Frank Z
    edited October 2007
    Since I've already put Pissant back on my ignore list, I'm going to guess that he's resorted to using all the big words he learned in Bible study.
  • SolidSqual
    edited October 2007
    I think Rodney King once said, "Can't we all just get along." Of course . . . I think he was beat down after that . . .
    treitz3 Posts: 19,959
    edited October 2007
    Thanks, now it's documented. Now we can go get a million dollars.:p
  • MGPK
    MGPK Posts: 88
    edited October 2007
    Frank Z wrote: »
    Next topic.
    Next topic:
    So...the topic today is the magical wonders of cables. According to Frank, cables possess wonderous capabilities of manipulating digital data, they can take those 1's and 0's and make them 2's and 3's, therefore expanding soundstages, making bass tighter while at the same time provide clearer treble. It has to be true, his ears don't lie and his acoustic memory is infallible to scientific data. But what can a buttmunching moron like me say after being in the industry for 15 years, having set up over 700 custom home theatres and doing numerous blind ABX tests.:rolleyes: Puuuhhleeeez
    System:
    H/K AVR430 Receiver
    Samsung DVDHD841 Dvd player
    Yamaha CDC506 5 Disc changer
    Jamo E855 Tower speakers
    Wharfdale Pacific P-10 Bookshelf speakers
    Acoustic Research Master Series Interconnects
  • ben62670
    ben62670 Posts: 15,969
    edited October 2007
    digital is dig to dig
    Optical is dig to light, and light to dig.
    Good coax is better on high res systems
    I was one to believe a 1 is a 1, and a 0 is a 0, but the extra 2 conversions are not needed
    K.I.S.S.
    Ben
  • Frank Z
    edited October 2007
    MGPK wrote: »
    Next topic:
    No, I said nothing of the sort. Read it again, it's really basic, simple actually. You might be able to grasp the basic concept.
    If a listener hears a better sound from one type of interconnect versus another, then the better of the two is the right choice. There are very few absolutes in this hobby and if you are to be believed, you should have learned that the day you became a box cutter. Dan has a really bad habit of assuming that his vast expeience stacking electrical components makes him the be-all, end-all expert for all things audio or video related. Problem is that his hearing is obstructed by all crap packed in his ears from having his head so firmly planted up his arse, so now everything sounds the same to him.
    Since you've only been here a short time let me tell you the same thing I told dannie-girl many moons ago when he started blabbering about his expertise at setting up home theaters...
    I've opened alot of canned vegatables, but that don't make me a farmer.
    So before you decide to prattle on about how your **** don't stink....back up and take a good long snort.
    Go away new meat...schools out.
  • SolidSqual
    edited October 2007
    I've also heard due to the conversion in Toslink, Coax is better.
  • Frank Z
    edited October 2007
    SolidSqual wrote: »
    SS, Don't base your decision on "What you've heard," base it on what YOU hear. Spend 20-30 minutes with a favorite CD or SACD and listen to both interconnects. You might notice a huge difference in sound quality, you may not notice any difference at all. It's all about what sounds the best to your ears brother. The only opinion that matters is yours.
  • SolidSqual
    edited October 2007
    Thanks . . . I know the party lines, more or less I was wondering if anyone could lend any credibility to the hear-say or strike it down as pure heresy. At any rate, the differences are sure to be minute. Unless . . . . This example: toslink from a computer will be bettered by Coax from an equivalent digital player. Atleast for now . . .
  • steveinaz
    edited October 2007
    It's easy to dismiss an idea when you over-simplify. Fiber optic cables do not carry electrical signals, so there are no impedance issues, no cable reflection induced jitter, and no way to pass a ground hum. Coaxial cable can, and does sometimes present these issues. These elements can most certainly have an acoustical impact.
    I did a 6 month experiment with this very topic using a quartz glass Toslink cable, then a coaxial, and eventually an XLR. The Toslink gave the most neutral presentation, albeit a bit "dry." XLR gave the most warm presentation, with Coax falling right in-between the two.
  • SolidSqual
    edited October 2007
    SO . . . so 1 does not equal 1 and 0 does not equal 0 in all cases where different interconnects are used, I would agree, but I don't like the Math.
  • steveinaz
    edited October 2007
    Keiko wrote: »
    My ears can't distinguish the difference between the 2. However, I prefer the coax because the connection is tighter and more secure.
    True. Connecting Toslink can be a real PITA, as I learned.
  • steveinaz
    edited October 2007
    SolidSqual wrote: »
    SO . . . so 1 does not equal 1 and 0 does not equal 0 in all cases...
    Exactly. Because there is far more going on than just 1's and 0's. If it were that simple, there would no difference between a Sony Walkman and Mark Levinson transport. Also remember, interconnects are electrical components. They can, and do influence the signal due to impedance anomolies, quality of materials used, and the topolgy employed.
    Keep in mind, my observations reflect a very subtle, yet distinguishable difference---nothing earth shattering or make-or-break type of difference. Again, it comes down to preference. I ended up using XLR, even though it was probably the most "colored" connection, I liked the warm tonal quality. Some listeners prefer a more analytical/articulate presentation, some don't.
  • SolidSqual
    edited October 2007
    Finally we have a solid conclusion in a cable thread. IF someone chimes in after this to say all cables sound the same and that metal is metal no matter if its copper, silver or gold . . . I will kill. I dare you to say glass fibers have the exact same properties as my $100 Signal interconnects or the hanger wire I bought from Target and attached bullet plugs to.
  • steveinaz
    edited October 2007
    FWIW, if you want to hear the difference with Toslink, put on some bass heavy music and switch between Toslink/coaxial. On my system, bass seems to extend lower and is tighter (better 'attack") via Toslink. But, overall Toslink was too neutral for me, almost dry sounding.
    Give it a try, let me know what you find.
  • PolkThug
    PolkThug Posts: 7,532
    edited October 2007
  • steveinaz
    edited October 2007
    Keiko wrote: »
    Aloha steveinaz. Nice to see you. :)
    Aloha :cool:
  • steveinaz
    edited October 2007
    Bottom line with these "which is better" type threads---you've got to test-drive it yourself. Everyone has their own idea about what music should sound like, and we all have our own preferences. Some people are casual listeners, some are nit-pickers.
