how to do the trunk?
eloplayspolo
k im doing my amp rack/box and finishing all my final stuff before i connect my amp(as soon as mtx sends it back).
1st Question: i have the dynamat to do the full trunk, do i really need to do everything, or just slap down some big pieces in a few specific places.
2nd Question: to come, after a take a pic for u guys
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
Mosconi 6to8 v8
Post edited by eloplayspolo on
they really big areas are whats important as they will do the most resonating , if your looking for a smooth finish in the trunk and your not covering the dynamat with upolstry of any kind a spray type lining will look the best.:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
its a brand new car i have the nice clean carpeting
2013 Toyota Prius
Mosconi 6to8 v8 -
I used Secondskin Damplifier all through out my trunk, including the trunk lid. I am very happy with the results.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
I already have my dynamat sitting in my garage, i didnt get to put it in my last car before i wrecked it.2013 Toyota Prius
Mosconi 6to8 v8 -
I have never had good results with dynamat. (probably the application i used it with) Although i do appreciate a clean sounding system i would suggest building the amp rack over the subs and as usual facing them towards the trunk.
Good luck, and if you can, recess the stuff down where the spare tire would normally be. that always looks cool -
you mainly want to get the side panels, the trunk lid, the rear of the car, the tag, and whatever's left if you have enought dynamat left.
If you want to buy dynamat, get the full 9 sheets one. That'll cover trunks and front speakers
Sell the Dynamat and get second skin or raammat.
you know dynamat is just going to deaden the flexing of any flat surfaces of the trunk WILL NOT prevent any rattles you have to pay attention to those rattles and see if you can either silicone / some dense foam ( do not use spray foam !! will squeek Under pressure and or buldge out quarter panels / trunk .. THE BEST WAY IS to port through ski hole / armrest / rear deck this will deffinatly increace you bass reflex 10 fold .......... then you would have to dynamat your cab instead of trunk and leave you some room in the trunk for amp rack ETC ................... Have fun !!!! oh and if your looking for a cheaper yet better replacement for dynamat look into HUSHMAT !! http://www.hushmat.com/
HMMM worked for me in my trunk and also for the license plates as well.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
