looking for spikes for my SDA2B
danger boy
danger boy Posts: 15,722
edited October 2007 in Vintage Speakers
I did a search and while I know this has been talked about on here before.. I wasn't able to come up with the info on where I can find some spikes for my 2B's and how they would attach to the bottom cap of them.
so I could use some help on which ones I should look at.
I'd like to keep this under $100 if I can.
suggestions are welcome!
advice needed. ;)
PolkFest 2012, who's going>?
Post edited by danger boy on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited October 2007
    Does the 2b not have threaded inserts in the bottom?
  • strider
    strider Posts: 2,568
    edited October 2007
    I know MillerLiteScott spiked his not too long ago, but I'm not certain what he used. If you don't here from anyone else, you may want to pm him as I think he's out of town right now.
    Wristwatch--->Crisco
  • woofiepaws
    woofiepaws Posts: 222
    edited October 2007
    Try here:
    http://www.oregondv.com/spikes.htm
    I have some of their spikes under my SRSs.
  • ka7niq
    ka7niq Posts: 577
    edited October 2007
    woofiepaws wrote: »
    Try here:
    Thanks Woofie!
    A great place you have turned us all onto, good stuff, great prices too :)
  • joeparaski
    joeparaski Posts: 1,865
    edited October 2007
    Here, try this, I ordered mine from there. http://www.canuckaudiomart.com/details/66285-isolation_cone_set_of_4/
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • Stew
    Stew Posts: 645
    edited October 2007
    I used SRS spikes from Polk (RF1400-1) with 1/4-20 threaded inserts from Lowe's on my 2b's. They're relatively easy to install (Drill 4 holes in the endcap, install the inserts with a hex key, thread the spikes into the inserts. Once height is adjusted, tighten nuts on spikes against inserts to lock.). They're easy to adjust and very inexpensive (Total cost for both speakers around $6.00).
    SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
    1000VA Dreadnought
    Dared SL-2000a (Siemens & Halske TM 12AT7WA's, Brimar 5Z4G)
    Jolida JD-100a (Sylvania BP TM Gold Brand 5751's), NAD C275BEE, Blue Jeans
    RTiA3, Onkyo TX-SR605
  • danger boy
    edited October 2007
    Stew wrote: »
    hey if it's not to much trouble.. can you post a picture here of what the finished spikes on the SDA's look like? It would be much appreciated.
    thanks
  • Stew
    Stew Posts: 645
    edited October 2007
    Sooner or later, I'm going to have to buy a digital camera! For now, I stole the following image from an old post by DarqueKnight. The spikes are black, so you really can't see them unless you put your face on the carpet next to the speaker. This picture show's the inserts and spikes but not the lock nut. I think they came with a nut but, if not, I added one.
    1000VA Dreadnought
  • danger boy
    edited October 2007
    so after you drilled the hole, and inserted the metal insert.. is that insert threaded too? then you just screw in the spike? I think I understand that part.
  • Stew
    Stew Posts: 645
    edited October 2007
    The insert has a coarse wood thread on the outside and a 1/4-20 thread on the inside. You screw the insert into the base with an allen wrench. The spike then threads into the insert. If you install a 1/4-20 nut onto the spike first, you can tighten the nut against the insert to lock in place once adjusted correctly. I think the spikes came with a 1/4-20 nut.
    Just make sure you drill the holes straight! I found a bushing with a hole slightly larger than the drill bit and held that against the base while drilling. I also marked the drill bit with a sharpie to make sure it didn't go all the way through the cabinet. Other than some very minor splintering of the veneer around the insert, it turned out great.
    1000VA Dreadnought
    heiney9 Posts: 25,408
    edited October 2007
    Try parts express as well. Rich gave me a set to install on my 1C's and they came from PE. In the end I decided not to drill holes in the oak for spikes.
  • danger boy
    edited October 2007
    the bottom oak cap on the 2B's isn't solid oak, it's pressed wood with oak trim only. the top cap is solid oak. why did they chump out on the bottom caps? ;)
    F1nut Posts: 51,693
    edited October 2007
    The top and bottom end caps are the same, veneer over MDF.
  • danger boy
    edited October 2007
    the bottom yes.. the top. sure feels like solid wood to me.. even the chip out of it. i can see the grain. oh hell. i'm going to be drilling the bottom end anyways. not the top.
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited October 2007
    I spiked my 2B's with the spikes from Parts Express, @ $40. Mostly because I could not afford to get the Mayes(SP) spikes. I would rather put my money into the crossovers at this point. I can always get them down the road and use the Parts Express spikes on another pair of speakers.
    The ones from Parts Express are not 1/4 20 threads. I think they are 10-32 which is the @ the same diameter but a finer thread.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • danger boy
    edited October 2007
    what do the numbers mean? 1/4 20 should I buy the spikes first then find the right hardware to use with them before drilling the holes?
  • MillerLiteScott
    edited October 2007
    The first number is the size of the screw/threaded rod and the second number is the number of threads per inch. The Parts Express comes with the inserts. I am not sure about other suppliers. But from what I have read most of them are 1/4 -20.
    Here are some pictures of the 2B's spiked. It is hard to take the picture to show them and the are on my storage side of my basement right now.
    Looks like I bent one.
  • MillerLiteScott
    edited October 2007
    danger boy wrote: »
    Yes.
    edited October 2007
    danger boy wrote: »
    My guess is 1/4 spike "20" referring to the thread count. Higher number means finer threads. The spikes come with their own treaded sleeves so they will match up with the spikes.
    I believe PE has 2 different sizes of spikes. Since it's a large heavy speaker I'd go with the biggest ones which are the 1/4" I think.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited October 2007
    IMHO these are the best brass spikes on the market. I use the middle point on the 1.2 TLs but F1nut has the bigguns on his SDAs. I plan on taking the spikes I currently have on the 1.2TLs moving them over to the CRS+ stands and getting the bigguns on the 1.2TLs.
  • danger boy
    edited October 2007
    spiking your stands? that seems a bit odd to me.. :confused:
  • hearingimpared
    edited October 2007
    danger boy wrote: »
    Then you better call Matt and tell him so, the stands come with real **** spikes!!!;) If you think about it Al it makes all the sense in the world. The stands are really just extensions of the CRSs and they are spiked to the floor through the stands.
    SCompRacer Posts: 9,089
    edited October 2007
    heiney9 wrote: »
    You gotta give em back then.:rolleyes: :p:D
    What did you use for that missing foot? IIRC, they were nailed on?
    edited October 2007
    SCompRacer wrote: »
    I used the spikes in the pair of stands my 5b's sit on (they already had the threaded inserts in the bottom plate), so they didn't go to waste :D . What foot :confused: ? If it's missing, it's not noticeable at all.
    edited October 2007
    heiney9 wrote: »
    They were not very thick. They looked like convex plastic bumps.
