Balanced interconnects for short runs?
john22614
john22614 Posts: 214
edited October 2007 in Electronics
I just purchased a new Outlaw 990 pre pro. It's their top of the line model and has balanced interconnect outputs that can hooked up to my Anthem amp.
Interested in anyone's opinion on wheter balanced interconnects offer noticeable sonic improvements over short distances.....in my case, six feet.
I really don't notice any noise problems in my current set up using standard blue jeans RCA interconnets.
Appreciate your thoughts. Thanks
B&W 804s mains
B&W HTM4 center
Polk PSW 1000 sub
Outlaw 990 Pre Amp
Anthem MCA 30 Amp
Monitor Radius 180 surrounds
Audiosource Stereo Amp for surrounds
Denon 2910 Universal DVD/SACD Player
Comcast DVR
Pioneer Elite 42" Plasma 940 HD
Harmony Universal Remote
Blue Jeans interconnects and biwires
Itunes Air Express
  • Systems
    Systems Posts: 14,872
    edited October 2007
    I looked into it pretty good when I got my Outlaw's. I was planning on getting an Integra pre pro with balanced out. What I read was pretty much the same that you note, balanced are better for longer runs but for 3 and 6 foot runs, not really different. That being said, if you got 'em, might as well use 'em
    Testing
    Testing
    Testing
  • Early B.
    Early B. Posts: 7,900
    edited October 2007
    Go with balanced cables, even if it's for piece of mind. On the design of some amps, balanced sounds better. But you won't know unless you try it.
    "God grooves with tubes."
  • venomclan
    venomclan Posts: 2,467
    edited October 2007
    I heard no difference on short runs between my equipment. The balanced connections can help with ground loops. There are 2 different camps regarding short runs for XLR and RCA. Some high end brands use just RCA, some both. There are also "fully balanced" equipment which differs from just XLR connections, but that is another story. Try and see for yourself.
    Venom
    heiney9 Posts: 25,724
    edited October 2007
    Early B. wrote: »
    This is very true, but there aren't a whole lot of designs out there that actually specify that using the balanced output results in better sound. Monarchy and Pass come to mind. Several reviewers as well as the designer of Monarchy amps specify balanced mode to get the most from the amp.
    The other thing to keep in mind is to really get any benefit from balanced connectors all the components in the chain should be balanced, that's rarely the case. The Monarchy and Pass stuff is the exception so I'm told.
  • rskarvan
    rskarvan Posts: 2,374
    edited October 2007
    Add Krell to your exception list. Balanced amp circuitry results in a 6 db drop in the noise floor. This allows the subtle details of the music to pass through.
    Balanced Amp, Balanced Preamp, & Balanced DAC for best performance!
    billbillw Posts: 8,370
    edited October 2007
    Really depends how the preamp and amp implement the balanced circuit and whether the entire circuit is a balanced design. True balanced circuits are rare and on many of the less expensive units, they use opamps to convert the balanced inputs/output, which will generally cause a degradation of sound. Obviously the higher end products that use a completely balanced design will sound better that way. I'd say, get a pair of cheap XLR cables from Bluejeans and try it. If it doesn't sound better, then sell them.
  • venomclan
    edited October 2007
    rskarvan wrote: »
    What amp do you use? I believe I have the same pre as you (Kav250p) and i heard no difference using balanced vs. rca to the amp, short runs.
    Venom
  • john22614
    edited October 2007
    I'm using an Anthem MCA 30.....3 channel/225 wpc at 8 ohms
    B&W 804s mains
    B&W HTM4 center
    Polk PSW 1000 sub
    Outlaw 990 Pre Amp
    Anthem MCA 30 Amp
    Comcast DVR
    Itunes Air Express
