to bridge or bi-amp?
Gridrah,
Would a pre-power amp x-over be the same as the speakers' internal? or is it scaled down for the reduced pre-amp out signal?
If you added the pre-power x-over, would the speakers' internal x-over have to be removed from the circuit?More later,
Tour...
Vox Copuli
I see benefits in Bi-amping...but my question is; on the Lsi9's am I to assume the top terminals are for the high frequency...??
Audio Physic Scorpio II
Pathos Logos
MIT Shotgun S3
Bada HD-22 CDP -
Imo, speakers don't DRAW, they are FED. Put a passive (or active) network BEFORE the amp in the chain, then we can talk about feedings.
Cheers,
RoosterCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Cheers,
Rooster
OK then... I have said I have an 800i in parallel with an RTA8T. If I remove the crossovers on both speaks and use an electronic crossover externally can I run only the highs, L/R and lows, L/R on 2 amps? I don't think impedance is a problem with the Outlaw.
Just a thought....
HBomb***WAREMTAE*** -
Originally posted by Tour2ma
Gridrah,
Yes and yes. They are typically rack mountable, but there are also sleek looking silver finished audiophile grade x-overs.
The main reason I'm interested in them is that I've been thinking about building some 2 way speakers. A cheap stereo 2-way (with sub x-over) can be had for around $100-150.Make it Funky!
