When a good speaker goes bad!
Audioinfidel
Audioinfidel Posts: 5
edited October 2007 in Vintage Speakers
I have recently acquired a pair of monitor 4.5's and am using one as my center channel with my 5b's.
Today I ran a test tone of 100hz and got a distorted sound after turning the volume up just past audible. Static is present at every frequency i tried from low to high when I reach a moderate sound level. I did a lot of **** and unscrewing and realized I'm getting a static sound from the mid bass driver and the tweeter. Why is the tweeter making static at 100hz?
I really haven't been listening to this speaker very loud, and the other one in the pair doesn't demonstrate this problem. Is it possible I blew the driver and tweeter, or could something be wrong with the crossover?
Any ideas anyone?
Thanks.
Post edited by Audioinfidel on
  • ka7niq
    ka7niq Posts: 577
    edited October 2007
    Any ideas anyone?
    Thanks.
    A test tone even at 100 hx could have enough energy to cause the tweter to show it is blown, or it may be a crossover problem ?
    TRY the drivers in the other speaker, see if they do the same in a working crossover ?
    I have to go, but I am sure the more knowledgeable Polk guys will help you more.
    Ciao
  • ohskigod
    ohskigod Posts: 6,505
    edited October 2007
    100hz?, its a long shot, but tighten the screws around the tweeter, might be a vibration that shows at that frequency
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • Audioinfidel
    edited October 2007
    I found that if I turned the voume up from 0 very slowly I could get the speaker to spit out around 80 db before the static noise/vibration started. However, the distortion stayed, regardless of how low I turned the volume until the voume went back to 0. Then I could turn it up again slowly without the noise.
    That makes it seem like the drivers are physically fine and its some kind of wiring/transistor problem? Anyone had a similar problem before?
  • beardog03
    beardog03 Posts: 5,550
    edited October 2007
    audio infidel...wwwwwwwwwwwwwaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    great name infidel !!
    welcome to the forum
    no I never had that problem.........ever
    Don`t know what it could be either....
    don`t use that speaker
    Problem solv--ed
    does it only do it on that one freq ?
    or all test tones?
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • Joe08867
    Joe08867 Posts: 3,919
    edited October 2007
    Try another speaker in place of that one with your Reciever/amp. I think your problem lies there.
    If it works fine with the new speaker I would say crossover. When you said the sound doesn't go away until you lower the amp makes me think Amp problem.
  • Audioinfidel
    edited October 2007
    After the problem disappeared but then started showing up on the other speaker on the other channel :eek: , I have determined its the amp. Its 17 years old and maybe it dirty or on its last legs. It is only an 8 ohm amp and these are 6 ohm speakers, so even though I'm not cranking it too high, it just can't always handle it.
    Thanks to everyone who commented. :rolleyes:
  • Joe08867
    edited October 2007
    I was right! :D
    Sorry to hear the amp is wacked out.:mad:
