Veneering a Subwoofer?
Early B.
Early B. Posts: 7,900
edited October 2007 in DIY, Mods & Tweaks
First of all, I don't know a damn thing about veneer, so the first question I have is -- can veneering be accomplished inexpensively by the novice whose woodworking skills are tentative, at best?
Here's what I'm interested in doing -- re-veneering a subwoofer (top and sides only) over the existing veneer???. It has rounded corners. I'm thinking the perfect scenario would be to use a single sheet, if possible, so I wouldn't have to fool around with cuts.
Is this too complicated a project for me to tackle?
Or would I be better off sanding and re-staining the existing veneer? I want a much darker color.
Thanks.
"God grooves with tubes."
Post edited by Early B. on
    VR3 Posts: 29,630
    edited October 2007
    Well what I'll tell you is -- hah
    You will most likely have to sand the existing veneer to reveneer the veneer --
    I would imagine
    I imagine the current veneer has a finish on it, which would lend me it is as of right now resisting moisture in some way. Some it would essentially overall not retain adhesion as well -- could be wrong, this is an assumption...
    But I would just refinish the current veneer.
  • Serendipity
    Serendipity Posts: 6,975
    edited October 2007
    I would imagine
    +1
    Looks like refinishing the current veneer is the best choice.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Early B.
    edited October 2007
    appadv wrote: »
    That's fine. Now what are the steps involved?
    I assume I'll have to apply a varnish remover of some sort, then sand it lightly, then apply several coats of medium walnut stain, then add a couple coats of poly?
  • Serendipity
    edited October 2007
    Early B. wrote: »
    Yup, that's basically it.
  • Deadof_knight
    Deadof_knight Posts: 980
    edited October 2007
    Yep what he said , I would let it air abit before sanding, wipe down the veneer with laquer thinner (as long as its not some sort of plastic veneer) laquer thinner will detroy anything plastic. let dry then sand using some sort of air to blow off dust real good, then use a light rub of thinner again then coat with clear after staining. if your going for a gloss finish use a finish sand paper such as 1500 damp lil water, wipe it down with a tack cloth and clear again to fill in low spots , wet sand once more with a block and then polish, it should turn out nice and shinnny!
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
