Best Tweeter upgrade for 10A's ??
lightman1
Just want to know the bast upgrade for my 10's without X-over mods.
Any info will help.
Any info will help.
Post edited by lightman1 on
A 10A should have the Peerless silk dome. What exactly do you think you'll upgrade (or do you have a bad one)?
Fuzzy. From what I can hear, around 6K on up. Al connections are solid.
