4 or 8 Ohms?
Mr. Mojo
The specs for the RM10 say nominal impedance 8 ohms, minimum impedance 4 ohms. The receiver I'm looking at (Onkyo 605) has 90 watts per channel at 8 ohms.
I have to buy the right gauge of speaker wire and was wondering if I should base it on 8 ohms (or 4)?
Thanks for any help!
Post edited by Mr. Mojo on
12 guage wire should be fine
and I believe they are 8 ohm
correct me if I`m wrong , guy`s...
oh, and welcome to the forum !!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
The Rm series is 8 ohms. I have the RM20s as rear surrounds and RM30s soon to be rear surround backs when I get my LSi25s up and running.
Zsolt -
Excellent.
Thanks for the quick response! -
New to this.
I just got the Yamaha RX-v3800 with Lsi 9s, Lsi fxs and the LsiC. I know the Lsis are 4 ohm, but I can only set the Yamaha at 8 or 6 ohms. Which one is best? Can this damage my speakers in any way? Thanks for the help. -
Ray, welcome. The provision for setting the receiver to a lower impedance is a type of safety measure required by various regulations, such as those of the UL(Underwriters Laboratory), to help prevent overheating of the amplifier. It in no way optimizes the receiver for driving the lower impedance speakers. The effect is to lower the maximum voltage that the power supply section of the receiver can deliver, and because of Ohm's Law, when the maximum voltage is reduced so is the maximum current and power available. Although this reduces the chance of overheating, it likewise reduces the performance capabilities of the unit. Leave the setting at 8 ohms and your 3800 should have no problem in driving the Lsis to very high sound levels. If there was a problem the protective circuits of the 3800 would simply shut it down, but there would be no damage to either the receiver or the speakers.
frazier.ray wrote: »New to this.
Your AVR isn't rated to drive 4 ohm loads, period. Time to shop for new power.Political Correctness'.........defined
President of Club Polk -
Gotta go with F1 on this one. a receiver that is not rated for the lower impedance of a speaker like the LSI series (4 ohm nominal) will most certainly shut down early and often.
I have the LSI15's and want a new AV receiver. I found the Denon 4308 to do everything I want. (HD Radio, Network[play for sure capability] HDMI 1.3a, 7.1 channel, etc. The only problem is that it is not rated for 4 ohms.. Only 8. Their website says it won't be a problem, but I don't necessarily believe it.
Does anyone have a suggestion for a AV receiver in the 2K price range. I'm trying to stay way from separates due to the cost and I don't really have to space for the separates....
Any help or suggestions would be appreciated.
Craig -
I have to agree with F1 and Frank. I am getting a set of LSi15's and needed to get a 4 ohm amp so i went with Outlaw 970 Preamp, and Outlaw 7125 Amp.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
That is a beautiful Yamaha AVR. Although I'm sure it would run your LSis adequately, it would be safer to go with a high current power amp. Your AVR is equipped with pre-outs to enable this. Lots of good equipment is out there, as well as nice used equipment. Some good suggestions can be had on this forum by the experts, in addition to stuff you can find in the archives. Good luck and enjoy.[
Very risky advise IMO. Probably the AVR's circuits will shut it down before the AVR is damaged.....but it could be too late for the speakers; very high sound levels? Not sure if the LSi line has any protection for the tweeters...I would not do this with my own equipment._________________________________________________
Running 5 4ohm speakers on an AVR is not the best idea. The way most AVR's amps are rated is with only 2 channels driven. They may have the watts but not enough amps to handle a 4ohm load. Even if the AVR will drive the speaker, you won't get the full performance that you can from the lsi. Do a search on this site for pages and pages on this subject.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
No pre amp outs so adding an amp is out. Need a amp that says it supports 4 ohms. 8 ohm amps can damaged 4 ohms speakers when they clip.
engtazengtaz
i'm just surprised how often I read this on here.. people using Yamaha receivers trying to power 4ohm speakers, then their AVR not having pre amp outs. just making an observation is all.PolkFest 2012, who's going>?
400W/CH@4ohms FTW!:D
It would take a lot of $$ to move up from this... -
That`s 15 min. away !
I wish I had the cash !!
Very nice unit...might get a good deal with the local pick-up...
Maybe not, who knows !!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
Well, that would certainly do it. (and sound great in the process) you could also look at B&K or Arcam recievers...Mains.............Polk LSi15 (Cherry)
No worries, this Yamaha AVR is equipped with preouts. Link listed below.
http://www.yamaha.com/yec/products/productdetail.html?CNTID=558316&CTID=5000300[
