Adcom 5400 or HK Citation 24 for RT1000p?
ViperZ
I am contemplating of selling one of my amps, and not sure which one to keep.
The amp will be used with my mains (RT1000p).
Adcom GFA-5400 is MOSFET based amp. Sound is very clear, I'd even say metallic.
Harman Kardon Citation 24 is BJT based amp. Sound is smooth as silk, very soft.
Any opinions on which amp would fit my mains better? I am kind of used to the Adcom, but got hesitant after listening to HK.
Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
B&W CDM1-SE fronts
B&W CDM-CNT center
The HK is a great match for the slightly hot tweeter of the RT lineup. I have run my RTi70s with the HK 24 and really liked it. With SDAs or the LSi line, it was too soft for my tastes though.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Spent most of my evening yesterday listening to those amp.. Switching between them.. Now hooked up one of them on the left channel, another on the right.. Still tough to compare with stereo sound. They do sound very different
BJT vs. MOSFET
Build quality is very similar
Power output is slightly higher with Adcom
Both are 4-Ohm stable easily
THD is slightly better in HK
(HK weighs in at 15 kg vs 12 kg for Adcom :cool: )
Arrrgh!Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Does anybody know what Class the HK amplifier is?
I found that Adcom is Class A (Class A/B at high(er) power).
I also found out that HK Citation 22 and 24 were built by Marantz for Harman Kardon. Funny...
Still can't pick one over another. Both have completely separated channels. Adcom advertises that even secondary windings in the toroidal transformer are separated. HK does not say much about transformer, but they claim that both channels are fully separated from pre-amp inputs to speaker outputs...Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
