Hand eye coordination
michael_w
michael_w Posts: 2,813
edited September 2007 in The Clubhouse
http://members.iinet.net.au/~pontipak/redsquare.html
I've only tried it a couple times but so far I'm at 20.109 seconds. It's harder than it looks...
Post edited by michael_w on
  • izafar
    izafar Posts: 820
    I believe doing this would also benefit from a high resolution gaming mouse
    -izafar
    Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
  • bobman1235
    bobman1235 Posts: 10,822
    I tried it but poked myself in the eye. I guess my coordination isn't very good.
  • michael_w
    I'm just using a Logitech mx400 at work (ditched the mx1000 for it). I'll give it a shot on my mx510 at home later and see if it helps... doubt it!
  • McLoki
    McLoki Posts: 5,231
    18.861 seconds....
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    It's all about figuring out the pattern. The objects move in the same pattern every time - you figure that out and you can actually do very well with minimal mouse movement...i.e. in this one you drop the red square straight down immediately then move to the upper left corner and you're good for 11 seconds or so, only moving the mouse a couple times...
    I saw this maybe a year ago and figured it out then, assume this is the same one...
  • audiobliss
    audiobliss Posts: 12,518
    Ha. I AM the master. Try and beat this. Just try. I dare you!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • audiobliss
    Ok, and here's a serious effort:
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • MacLeod
    MacLeod Posts: 14,358
    23.5 seconds!!
    How the hell do you save screen shots like that and post them?
  • audiobliss
    Nevermind that...how the heck do you get 23.5 seconds?!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • MacLeod
    Ive been playing video games for nearly 30 years. ;)
    24.672 seconds! :D
  • Systems
    Systems Posts: 14,872
    Got 24 seconds after about 10 trys and then my ADD kicked in.
    One of the keys is to watch out for the long one, that one got me most the time. Either that or a crappy mouse movement/jump
    Testing
    Testing
    Testing
  • McLoki
    McLoki Posts: 5,231
    Here you go, 26.03 seconds...
  • BaggedLancer
    BaggedLancer Posts: 6,371
    Not even gonna try.....I might end up hurting myself or my computer equipment.
  • beardog03
    beardog03 Posts: 5,550
    .035
    wooohoo
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • McLoki
    McLoki Posts: 5,231
    MacLeod wrote: »
    23.5 seconds!!
    1. shift-printscreen to copy the entire screen - alt-printscreen to copy the active window.
    2. Paste the image (ctrl-V) into paint
    3. Resize the paint screen to fit the image (grab a corner)
    4. save as a .jpg file.
    5. attach it to your post.
    Just like that.
  • jcaut
    jcaut Posts: 1,849
    I did pretty good in about 12 tries:
  • thejck
    thejck Posts: 849
  • MacLeod
    McLoki wrote: »
    Just like that.
    Thanks! Ive seen this done a bunch over the years but could never figure it out and didnt want to show my ignorance by asking. But I figured that after 11,000 posts my ignorance is pretty well established so what the hell! :D
  • thejck
    thejck Posts: 849
    if you hold down the alt key as well as print screen it will only copy the window thats active. then you can just paste that one
  • McLoki
    McLoki Posts: 5,231
    thejck wrote: »
    Re-read step one... ;)
