which amp?
1lakerfan
1lakerfan Posts: 112
edited October 2007 in Car Audio & Electronics
whats the best amp to go with the Polk Audio db212-2 for around $200?
Post edited by 1lakerfan on
  • MacLeod
    MacLeod Posts: 14,358
    edited September 2007
    Not much to choose from when youre looking for a 700 watt Class D amp for $200 but this one is ok.
    Its extreme entry level but itll work.
    http://www.cardomain.com/item/POWA1000DB
  • 1lakerfan
    how much do you recommened spending at least to really get the bass going
  • 1lakerfan
  • MacLeod
    Spend as much as you can within reason. You get what you pay for.
    That MTX is a very solid amp. Id rather use 800 watts on those subs, but 600 will work fine.
  • killerb
    killerb Posts: 390
    kenwood excelon kdc-x991 h.u.
    Rockford Fosgate 360.3 DSP
    Rockford Fosgate POWER1000 running entire system
    Image Dynamics IDQ12 Sub
    Morel Elate 6 front stage
  • Greg Peters
    Greg Peters Posts: 605
    http://www.cadencestore.com/ProductCart/pc/viewPrd.asp?idcategory=125&idproduct=380
    A little less than 700 watts RMS @ 2 ohms, I know, BUT...rated at 13.8 V rather than the usual 14.4V- there's no guarantee you'll get 14.4V at the amp in every vehicle without electrical enhancements.
  • JoshParsons84
    JoshParsons84 Posts: 565
    What about Polk amps? How do they sound? I'm asking for the 4-channel and for the mono block. How does the 4-channel sound hooked up on a pair of db6501 and a pair of db690? And then how does the mono amp sound hooked up on some db212-2, but later on hooked up to 2 SR 12" DVC?
  • killerb
    killerb Posts: 390
    i love the polk amps, but i think he needs more power.
  • 1lakerfan
    how much do you recommened I should spend on speakers I was thinking 200-250
  • killerb
    killerb Posts: 390
    for that price range i highly recommend these. they are made by morel and are carbon copies of the famous morel elate components. i got a pair for my girls car after owning the morel elates and they sound exactly the same for a fraction of the price. great power handleing, great mid bass, and smooth highs. the best bang for the buck!!!
    http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1236
  • bknauss
    bknauss Posts: 1,441
    Polk C500.1
    Brian Knauss
    ex-Electrical Engineer for Polk
  • 1996blackmax
    1996blackmax Posts: 2,436
    You can pick up a used Kicker ZX750.1 for that price. Solid amps that will put out alot of power. I ran one of those for a while
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • 1lakerfan
    killerb wrote: »
    Are these really that good? never heard of that brand.
  • killerb
    killerb Posts: 390
    yes, these are killer speakers!! they have a mid with a 3" voice coil and a tweeter with a very low resonant freq. a best buy for the price. grab a pair, you wont be disapointed.
  • ka7niq
    ka7niq Posts: 577
    check out the Cadence amps, great for the money!
  • MacLeod
    Those PG speakers are made by Morel. Thats always a good thing!!
  • 1lakerfan
    killerb wrote: »
    Are they better than polks componets speakers (seen some for around $200). Its just that when I hear car audio I think of brands like kicker, mtx, infinity and so on, I just want to know they are going to be reliable speakers when they start to get older.
  • 1996blackmax
    Those brands you mentioned are good brands, but there are so many more brands out there that offer very high quality equipment. Take my speakers, they are made by Rainbow, a company that alot of people have not really heard of. I've had them for going on 2 years soon, and they still sound great. If they do develop an issue, they come with a five year manufacturer's warranty. This also shows how confident the company is in the longevity of their products.
    Those speakers are made by Morel, they are very well known for producing very good compoents (not just good sounding, but overall high quality products).
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • 1lakerfan
    edited October 2007
    I decided to higher my budget for a 1 ch amp for the Polk Audio db212-2 to no more than $450....so which one?
