LSI25 W/LSI15 surrounds
askinquestions
Has anyone in here put this set-up together. LSI25 fronts and LSI15 for the surrounds. Does this make that huge of a difference from the lsifx??? I know the price is a lot different, but for the money, will it put that "WOW" factor in there, or will it be, lsifx would of worked just as good if not better????
PS: I have the juice to run either...
Post edited by askinquestions on
If I had the room layout, I'd definetly use the LSiFX for surrounds over the 15's.
FYI, I'm currently using LSi15 mains and LSi15 surrounds. My room layout doesn't allow me to use the FX's. -
Wow - I found my home theatre twin in MikeC78 in Bloomington. I'm doing the same exact thing Mike is doing for the exact same reasons (4 x LSi15), and concur with Mike that if possible, the LSiFX would be a better surround fit - in our opinion
Do you hear that buzzing noise?
Mikes setup is pretty good, but mounting the 15's on the wall so they could be twisted and tilted was a pain in the ****. You would think Polk would at least put keyhole slots on the back of their towers.....
Michael
Waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa!!!!!!!!
I could only wish... Otherwise, we would of done that at the PF.:o
Another alternative method would be to hang them from the ceiling with some sturdy twine. Problem solved.
You could just "in-wall" the 15s and be done with it.Do you hear that buzzing noise?
