Trying To Perform Firmwhere Update
shahmichael@com
Guys help,how can I download firmwhere update on Toshiba A20.I only have one lan port on my pc,and if I unplug it to plug in lan-line out to hd-player I will loose internet conect.I have comcast and it is conected through lan port on back of modem.If I unplug I will have no internet and cant download from it to player.
Post edited by shahmichael@com on
It has to see a LAN connection for a firmware upgrade? I thought a lot of them just flashed the memory via a CD or DVD-ROM disc. I could be wrong as I know nothing about that unit. Otherwise, you would need a 2 or 4-hub router.Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
Could you download the update to your computer, store it on your hard drive or burn it to a disc, disconnect from the internet, connect the Toshiba, and install the update?McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers.
Here's what I see on their website. If you have a CD or DVD burner, it looks like you may be able to put the file on there. The direct LAN connection is cool if you have a router...takes about 20 minutes it says.Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
I did it this way, it worked just fine. Word is it's quicker too.If you will it, dude, it is no dream. -
Guys I have been trying to burn this iso-file all day-no luck.I downloaded iso recorder and when I get to screen to record to disc it says no media.It sees the file name but no data to burn.I am stumped,have tried many times but record wizard keeps saying no mediai
No media means you have no disc in the drive. You did put a blank disc in your CD burner right?If you will it, dude, it is no dream.
Did you unzip the ISO file?Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
I did have a disc in the reader,but I did not nu-zip file,I just followed what I read from iso recorder site.
Bobman1235 seems right,when recording wizard screen is up it shows iso image to be copied but in the recorder part of screen is says no media I guess that means no disc.I have tried different discs still no media.
Have your burned Cd's before? If not you may not have a burner at all.
Or your burner can't handle the CD format you are using. Try a smaller volume CD and see if it works. -
I have burned music cd's before,but my computer says DVD-r/CD-rw record.I am using CD-r disc maybe my machine isn't recognizing CD-r disc and may I should use CD-rw disc.Is there any difference.
If CD-RW works, CD-R should work. RW is just re-writable.
Do you ahve any other program you could use to do the burning?
The other option is to send away to Toshiba for an update on CD. It takes a little longer, but this doesn't appear to be flying along either.If you will it, dude, it is no dream. -
Can't you hook up your ethernet connection directly to the HD-A20? I believe I hooked mine directly to the moden, and it worked fine.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
That's what I was thinking. Just take the player close to the PC and unhook the ethernet connection from the PC and hook it to the DVD player. It's only supposed to take 20 minutes or so. You don't have to be on the PC for the update to do its thing.
Here's exactly what the website says about the ethernet connection...
How to obtain and install the firmware update:
1. If you have broadband internet service, you may obtain the firmware update over the internet using the Ethernet port on the back of your HD DVD Player. Instructions for configuring the Ethernet port and downloading the firmware update can be found in the owner's manual and Update Procedure sheet for your HD DVD Player. Here is an overview of the process:
* BEFORE BEGINNING THE FIRMWARE UPDATE PROCESS, BE SURE TO REMOVE ANY DISCS FROM YOUR HD DVD PLAYER.
* Please configure the Ethernet port. You may need to turn on DHCP and DNS.
* After you have configured the Ethernet port, follow the directions in the owners manual to check for a firmware update.
* If a firmware update is available for your player, it will take about 20 minutes to download and install.
Once the firmware update download process has finished;
1. A message will appear, and the firmware update will automatically start.
2. When the firmware update is completed, the player will automatically turn itself off.Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner. -
I tried writing a video cd with photo on it and it comes back error every time,so the problem is this computer.I did already dend away for update.What is weired is it says this machine does what Iam trying to do.:mad:
If I unhook lan connect from back of pc,then how does the player know what to do.Once I unhook earthnet plug I will loose internet on screen,how will I know program is being downloaded if I cant see on screen because I wont have internet.
The directions say to look in your owners manual. THAT's where the directions are. The player will tell you on it's screen what's going on. It might work like that, it might not. It's just an idea. But look in the owners manual!Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
Um... what?
The internet connection is currently connected to your PC.
It needs to be connected to your HD-DVD player.
You will know how it's progressing because you ahve to have some sort of display hooked up to the DVD player. Your PC has NOTHING to do with it. You don't even NEED a PC for that part to work. The HD-DVD player IS the PC in this example.If you will it, dude, it is no dream. -
Ok,the player will automaticly read download.So you really dont need pc,I got it.Now all I need is adapter for comcast line going from phone modem to pc,comcast line has larger plug on it.
There isn't a standard Cat5 cable hooked up from the modem to the PC?Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
shahmichael@com wrote: »Ok,the player will automaticly read download.So you really dont need pc,I got it.Now all I need is adapter for comcast line going from phone modem to pc,comcast line has larger plug on it.
are you talking about a regular phone jack instead of an ethernet jack? the two look similar but you want to use the bigger one for your a20. do you have comcast high-speed internet, or slow internet through the phone line? i didn't know comcast offers dial-up.
anyway, i hope you mean you have high-speed internet and it uses the larger ethernet plug. just take your a20 over to your internet connection and hook it up to a small tv so you can confirm the a20 is progressing. don't worry, the a20 will go to the correct website on its own, so you don't need the pc at all, only an internet connection. but be sure you can see the progress of the update on your screen. you DO NOT want to turn off the a20 in the middle of downloading the firmware!
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
Well I did what the manual said,I did what everyone on here said and the player wont take the download.I did what you guys said to try,I moved the player next to computer,plugged earth net plug into player,put player in setup mode turned dhcp and dns on and it goes into confirm status but wont download,tried a hundred times no luck.Tried putting in address,subnet mask,gateway,dns server info,nothing happens.I have to wait for Toshiba disc to arrive.I am disappointed the download wont take.
Which update are you trying to download? I may be able to burn a copy for you and mail it to you.Money Talks, Mine says Goodbye Rob!!!!
Well it ends up my player wont recognize my INTERNET server,I have comcast and I have digital phone modem all from comcast.I called comcast and got all of the address,I knew I hated comcast before now more then ever,all I'm trying to do is download update 2.5.
How do you have this connected? Do you have a home router at all? If not get one. I don't know how this firmware update works, but I do work in IT and know a thing or 2 about networking. If you give me some more details I might be able to help you. You have to transfer a file from your pc to your player? Seems like a funny way to implement a firmware update using ethernet, they could have designed it so you just burn an image to a cd. If the player has an ethernet port can it stream from a server?
Yeah, it really sounds like Comcast is your problem... :rolleyes:If you will it, dude, it is no dream.
