Trying To Perform Firmwhere Update
shahmichael@com
shahmichael@com Posts: 55
edited September 2007 in Electronics
Guys help,how can I download firmwhere update on Toshiba A20.I only have one lan port on my pc,and if I unplug it to plug in lan-line out to hd-player I will loose internet conect.I have comcast and it is conected through lan port on back of modem.If I unplug I will have no internet and cant download from it to player.
    PIONEER ELITE 74TXVI-AVR,PARASOUND HCA 1000A-AMP.,JVC SR TS1U S-VIDEO VCR,DENON DCM 460 5DISC CD PLAYER,LUXMAN PD270 DIRECT DRIVE TURNTABLE W/ADC ARM,PA-CS400I CENTER,PA-FXI30 SIDE SURROUNDS,PA-RTI4 REAR SURROUNDS,CERWIN VEGA-211R MAINS,PA-PSW12 SUBWOOFER,BELLO-5TIER RACK,MONSTER WIRING,DIRECT TV HR21-700 HD-DVR,SONY-KP51WS510 51"HDTV,TOSHIBA-A20 HD-DVD PLAYER,ROTEL RB-971 2 CHANNEL AMP,LOGITECH-HARMONY 676 UNIVERSAL REMOTE,MONSTER-2600MKII POWER CONDITIONER
    Post edited by shahmichael@com on
    • avguytx
      avguytx Posts: 1,628
      It has to see a LAN connection for a firmware upgrade? I thought a lot of them just flashed the memory via a CD or DVD-ROM disc. I could be wrong as I know nothing about that unit. Otherwise, you would need a 2 or 4-hub router.
      Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
    • mark090852
      mark090852 Posts: 1,001
      Could you download the update to your computer, store it on your hard drive or burn it to a disc, disconnect from the internet, connect the Toshiba, and install the update?
      McIntosh MA352 Integrated Amp, Bluesound Node Icon Reference Network Music Streamer, SVS Ultra Evolution Pinnacle Speakers
    • avguytx
      Here's what I see on their website. If you have a CD or DVD burner, it looks like you may be able to put the file on there. The direct LAN connection is cool if you have a router...takes about 20 minutes it says.
    • bobman1235
      bobman1235 Posts: 10,822
      avguytx wrote: »
      I did it this way, it worked just fine. Word is it's quicker too.
    • shahmichael@com
      Guys I have been trying to burn this iso-file all day-no luck.I downloaded iso recorder and when I get to screen to record to disc it says no media.It sees the file name but no data to burn.I am stumped,have tried many times but record wizard keeps saying no mediai:confused:
      • bobman1235
        No media means you have no disc in the drive. You did put a blank disc in your CD burner right?
      • ViperZ
        ViperZ Posts: 2,046
        Did you unzip the ISO file?
        Panasonic PT-AE4000U projector for movies
        Denon AVR-X3600H pre/pro
        B&W CDM1-SE fronts
        B&W CDM-CNT center
        B&W CDM1 rears on MoPADs
        DUAL NHT SubTwo subwoofers
        Oppo BDP-93 Blu-Ray player
        Belkin PF60 Power Center
        Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
      • shahmichael@com
        I did have a disc in the reader,but I did not nu-zip file,I just followed what I read from iso recorder site.
        • shahmichael@com
          Bobman1235 seems right,when recording wizard screen is up it shows iso image to be copied but in the recorder part of screen is says no media I guess that means no disc.I have tried different discs still no media.
          • Joe08867
            Joe08867 Posts: 3,919
            Have your burned Cd's before? If not you may not have a burner at all.
            Or your burner can't handle the CD format you are using. Try a smaller volume CD and see if it works.
          • shahmichael@com
            I have burned music cd's before,but my computer says DVD-r/CD-rw record.I am using CD-r disc maybe my machine isn't recognizing CD-r disc and may I should use CD-rw disc.Is there any difference.
            • bobman1235
              If CD-RW works, CD-R should work. RW is just re-writable.
              Do you ahve any other program you could use to do the burning?
              The other option is to send away to Toshiba for an update on CD. It takes a little longer, but this doesn't appear to be flying along either.
            • AndyGwis
              AndyGwis Posts: 3,655
              Can't you hook up your ethernet connection directly to the HD-A20? I believe I hooked mine directly to the moden, and it worked fine.
              Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
              Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
            • avguytx
              That's what I was thinking. Just take the player close to the PC and unhook the ethernet connection from the PC and hook it to the DVD player. It's only supposed to take 20 minutes or so. You don't have to be on the PC for the update to do its thing.
              Here's exactly what the website says about the ethernet connection...
              How to obtain and install the firmware update:
              1. If you have broadband internet service, you may obtain the firmware update over the internet using the Ethernet port on the back of your HD DVD Player. Instructions for configuring the Ethernet port and downloading the firmware update can be found in the owner's manual and Update Procedure sheet for your HD DVD Player. Here is an overview of the process:
              * BEFORE BEGINNING THE FIRMWARE UPDATE PROCESS, BE SURE TO REMOVE ANY DISCS FROM YOUR HD DVD PLAYER.
              * Please configure the Ethernet port. You may need to turn on DHCP and DNS.
              * After you have configured the Ethernet port, follow the directions in the owner’s manual to check for a firmware update.
              * If a firmware update is available for your player, it will take about 20 minutes to download and install.
              Once the firmware update download process has finished;
              1. A message will appear, and the firmware update will automatically start.
              2. When the firmware update is completed, the player will automatically turn itself off.
            • shahmichael@com
              I tried writing a video cd with photo on it and it comes back error every time,so the problem is this computer.I did already dend away for update.What is weired is it says this machine does what Iam trying to do.:mad:
              • shahmichael@com
                If I unhook lan connect from back of pc,then how does the player know what to do.Once I unhook earthnet plug I will loose internet on screen,how will I know program is being downloaded if I cant see on screen because I wont have internet.
                • avguytx
                  The directions say to look in your owners manual. THAT's where the directions are. The player will tell you on it's screen what's going on. It might work like that, it might not. It's just an idea. But look in the owners manual!
                • bobman1235
                  Um... what?
                  The internet connection is currently connected to your PC.
                  It needs to be connected to your HD-DVD player.
                  You will know how it's progressing because you ahve to have some sort of display hooked up to the DVD player. Your PC has NOTHING to do with it. You don't even NEED a PC for that part to work. The HD-DVD player IS the PC in this example.
                • shahmichael@com
                  Ok,the player will automaticly read download.So you really dont need pc,I got it.Now all I need is adapter for comcast line going from phone modem to pc,comcast line has larger plug on it.
                  • avguytx
                    There isn't a standard Cat5 cable hooked up from the modem to the PC?
                  • BIZILL
                    BIZILL Posts: 5,432
                    are you talking about a regular phone jack instead of an ethernet jack? the two look similar but you want to use the bigger one for your a20. do you have comcast high-speed internet, or slow internet through the phone line? i didn't know comcast offers dial-up.
                    anyway, i hope you mean you have high-speed internet and it uses the larger ethernet plug. just take your a20 over to your internet connection and hook it up to a small tv so you can confirm the a20 is progressing. don't worry, the a20 will go to the correct website on its own, so you don't need the pc at all, only an internet connection. but be sure you can see the progress of the update on your screen. you DO NOT want to turn off the a20 in the middle of downloading the firmware!
                    ONKYO TX-SR805
                    CENTER: CSI5
                    MAINS: RTI8'S
                    SURROUNDS: RTI8'S
                    7.1 SURROUNDS: RTI6'S
                    XBOX 360
                    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
                    http://polkarmy.com/forums/index.php
                    bobman1235 wrote:
                    I have no facts to back that up, but I never let facts get in the way of my arguments.
                  • shahmichael@com
                    Well I did what the manual said,I did what everyone on here said and the player wont take the download.I did what you guys said to try,I moved the player next to computer,plugged earth net plug into player,put player in setup mode turned dhcp and dns on and it goes into confirm status but wont download,tried a hundred times no luck.Tried putting in address,subnet mask,gateway,dns server info,nothing happens.I have to wait for Toshiba disc to arrive.I am disappointed the download wont take.:confused:
                    • Grimster74
                      Grimster74 Posts: 2,577
                      Which update are you trying to download? I may be able to burn a copy for you and mail it to you.
                    • shahmichael@com
                      Well it ends up my player wont recognize my INTERNET server,I have comcast and I have digital phone modem all from comcast.I called comcast and got all of the address,I knew I hated comcast before now more then ever,all I'm trying to do is download update 2.5.
                      • hypertone
                        hypertone Posts: 150
                        How do you have this connected? Do you have a home router at all? If not get one. I don't know how this firmware update works, but I do work in IT and know a thing or 2 about networking. If you give me some more details I might be able to help you. You have to transfer a file from your pc to your player? Seems like a funny way to implement a firmware update using ethernet, they could have designed it so you just burn an image to a cd. If the player has an ethernet port can it stream from a server?
                      • bobman1235
                        Yeah, it really sounds like Comcast is your problem... :rolleyes:
