Anybody familiar with Microsoft Works Spreadsheet?
dragon1952
This thing is driving me insane. It does this thing every 10 secs where the hour glass blinks twice and you can't input anything for around 2 seconds. It's not the auto save because that's set for 10 minutes. Anybody know what it is and how to turn it off. I've checked everything I can think of.
Post edited by dragon1952 on
It's BIG BOTHER watching you
Other then that no idea, but you're talking about Excel right?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
No not Excel. The cheapass Microsoft Works spreadsheet that comes with XP.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
I didn't even know Microsoft had spreadsheet something that came with XP.
Learn something everyday.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I'd hit CTRL-ALT-DEL and select "Task Manager (TM)," select the tab along the top called "Processes" and click in the column "CPU" one or two times to get the big numbers at the top to sort on what process is using your CPUs horsepower up. Get your Works spreadsheet next to the TM window and see if there's a corresponding spike in CPU usage when your spreadsheet is stalling.
Sometimes when I get these kinds of problems, I run Registry Mechanic, it's the best money ($30) I've spent on computer improvement. (No affiliation) -
Yeah, thanks but that's the first thing I tried but I didn't see anything unusual at first.
Now that I know the process name of the spreadsheet though I notice that the hourglass corresponds to a jump from 0 to 8% CPU usage and a memory usage increase of about 52KB by the spreadsheet process. The total memory used by that program jumps by that 52KB every 10 secs even when I'm not making any changes. Maybe it's got a memory leak or something.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
Typically "works" is an older version of "Office" with very minor changes.Testing
Testing
Testing
