Amplifier Temperatures
MillerLiteScott
MillerLiteScott Posts: 2,564
edited October 2007 in Electronics
My amp runs @ 20 degrees cooler running my RTA 11t's than my SDA 2B's.
RTA 11t's @ 90 F
SDA 2B's @ 110 F
I thought that was pretty significant.
Scott
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Post edited by MillerLiteScott on
  • danger boy
    danger boy Posts: 15,722
    edited September 2007
    that is a big difference.. i just found out this integrated amp i just got also runs pretty hot running SDA 2B's. do you know are they 4 or 6ohm speakers?
    PolkFest 2012, who's going>?
  • MillerLiteScott
    I thought that 2B's were 8 ohm compatible. I could be wrong and such as.
  • cfrizz
    cfrizz Posts: 13,415
    Those SDA's obviously require a lot more power! COOL.
  • strider
    strider Posts: 2,568
    IIRC, they are labelled as 8 ohm compatible, but are 6 ohm nominally.
    Wristwatch--->Crisco
  • Willow
    Willow Posts: 11,231
    I'll test the temp on my monos and my AVR
    heiney9 Posts: 25,432
    I think it has to do with the SDA cable. With my SDA 1C's my amp is warmer at idle than when I had my LSi 9's and runs about as hot as when I play them above a normal listening level. The SDA cable puts a bit more strain on the negative side of the amplifier. Nothing to worry about if you have a nice robust amplifier, if not then time will tell. It's not *always* about nominal impedence rating.
  • Systems
    Systems Posts: 14,873
    I've had my Outlaw monoblocks funning at full blast for an hour and the things barely feel warmer then room temp! On the flip side, my Onkyo 805 using full preouts will be so hot that I cant even leave my hand on it.
    Testing
    Testing
    Testing
    Silverti wrote: »
    The Outlaw mono's are class H amps so if they get hot you have a problem ;).
    F1nut Posts: 51,749
    Hilarious!
  • MillerLiteScott
    edited October 2007
    RTA 11t's @ 90 F
    SDA 2B's @ 110 F
    Scott
    My amp powering Monitor 5's under the same conditions runs @ 82 F
  • ViperZ
    ViperZ Posts: 2,046
    edited October 2007
    Really depends on the class of your amp and on technology used in the amp, as someone mentioned.
    i.e. My MOSFET-based Adcom is Class A at low power, and class AB at higher power. If I let it idle, it does get very warm (class A).
    On the other hand my BJT-based HK amp (not sure of class of amplifier) always runs stone cold (the heatsinks on main transistors are cool).
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
