Input Question...CD vs Aux
beardog03
beardog03 Posts: 5,550
edited September 2007 in 2 Channel Audio
Is there a big difference between using the Aux input and the actual CD input on the pre amp ?
I mean as far as the circuitry and performance.
I have the Jolida going through the CD input and the AH! 4000 going through the Aux input on the Cary, and while I know that there is a difference sonically between the AQ cables and the MIT cables, am I going to get a different/less direct/lesser sound by using the aux input instead of the cd input on the pre amp ?
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
  • steveinaz
    steveinaz Posts: 19,546
    None, they are both line level inputs.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Some pre/int amps have either a cd 'direct' switch you can engage, or run the cd input as short and clean as possible, perhaps bypassing tone / balance controls etc.
    Your preamp may have a more direct circuit for the cd input, while the other inputs might be massaged a little for tape and other sources. It may simply just be another line level input.
    Cheers,
    Russ
  • madmax
    madmax Posts: 12,434
    Some preamps also have a direct in or a tape in which makes for a shorter input line/less messing with the signal.
    Vinyl, the final frontier...
  • beardog03
    THanks guys !
    I`m trying to A/B the Jolida and The AH! to see which one has better synergy with this set-up...
    I really need to get another set of MIT`s to do it right though
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • RuSsMaN
    Surely you have two pair of something, just to test each, no?
  • beardog03
    I do...
    Looks like the AQ King Cobra`s, or Diamondbacks...
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
