Input Question...CD vs Aux
beardog03
Is there a big difference between using the Aux input and the actual CD input on the pre amp ?
I mean as far as the circuitry and performance.
I have the Jolida going through the CD input and the AH! 4000 going through the Aux input on the Cary, and while I know that there is a difference sonically between the AQ cables and the MIT cables, am I going to get a different/less direct/lesser sound by using the aux input instead of the cd input on the pre amp ?
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool:
None, they are both line level inputs.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Some pre/int amps have either a cd 'direct' switch you can engage, or run the cd input as short and clean as possible, perhaps bypassing tone / balance controls etc.
Your preamp may have a more direct circuit for the cd input, while the other inputs might be massaged a little for tape and other sources. It may simply just be another line level input.
Cheers,
Some preamps also have a direct in or a tape in which makes for a shorter input line/less messing with the signal.Vinyl, the final frontier...
THanks guys !
I`m trying to A/B the Jolida and The AH! to see which one has better synergy with this set-up...
I really need to get another set of MIT`s to do it right thoughCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
Surely you have two pair of something, just to test each, no?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
I do...
Looks like the AQ King Cobra`s, or Diamondbacks...Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool:
