dynamat
eloplayspolo
eloplayspolo Posts: 1,117
edited September 2007 in Car Audio & Electronics
Dynmat CAN short a speaker connection if it is touch both positive and negative correct?
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
Post edited by eloplayspolo on
  • beardog03
    beardog03 Posts: 5,550
    I believe the foil covering can be conductive...
    Mac, Cody ?
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • MacLeod
    MacLeod Posts: 14,358
    Ya know, Ive never thought about it but it is an but it is an aluminum backing so I would say yes it could be possible.
  • eloplayspolo
    well i mean its on my rear deck, and my speaker is pushed through the hole Tight as a virgin on prom night, which is a good thing of course, just the speaker doesnt play music when i connect it to the head unit, so im thinking thats what it is.
    2013 Toyota Prius
    Mosconi 6to8 v8
  • 1996blackmax
    1996blackmax Posts: 2,436
    Clean out the area around the speaker connections...
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • eloplayspolo
    lol thats what i was planning on doing, dont sass me. BUt i wanted to make sure that it WAS possible for dynamat to short out a speaker.
    2013 Toyota Prius
    Mosconi 6to8 v8
  • 1996blackmax
    I did not want to take a chance, so I always made sure that the area around the connections were clear of at least the foil part.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • [Deleted User]
    [Deleted User] Posts: 763
    YES! It is absolutely conductive.
  • exalted512
    exalted512 Posts: 10,734
    Josh wrote: »
    word to your mother.
    Thought of the day kids:
    Yes, metal is conductive...yay!
    -Cody
  • exalted512
    and on a side note, it is also a bad idea to put it in the microwave to heat it up, just in case you were wondering.
    -Cody
  • Joelsbass
    Joelsbass Posts: 637
    exalted512 wrote: »
    -Cody
    So much for my plans of dynamatting this winter :p
    MacLeod: I guess youre lucky Polk has such lax hiring standards.
    Josh: Damn skippy!
  • eloplayspolo
    hahahaha thanks. Too bad Southern California Sunshine > than winter when it comes to dynamating.
    2013 Toyota Prius
    Mosconi 6to8 v8
  • exalted512
    When I was doing my floor in the winter, I would start the truck and put my damplifier under the hood to heat it up.
    -Cody
  • 1996blackmax
    I've used my heatgun before.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • najahaja
    najahaja Posts: 32
    a heatgun will be fine, as it will make the mat more malleable. However, I think what exalted512 was getting at is that the alluminium in the microwave would cause that arcing seen when putting metallic items in :)
  • eloplayspolo
    anyone ever dry the dish washer on the pots and pans cycle
    2013 Toyota Prius
    Mosconi 6to8 v8
  • 1996blackmax
    najahaja wrote: »
    I know.... I was stating what esle will work.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • Joelsbass
    Joelsbass wrote: »
    I was making the joke that I was planning on using my microwave to heat dynamat for a winter install.... :p
    Josh: Damn skippy!
