Polk Audio DB6501
cam5860
Well I finally Got My kenwood Excelon amp installed and my 6.5 component set also. The mid driver is a pain to install because the mounting holes are wider than a standard 6.5 install, and the spacers work but looked like **** in my install. So I had to drill 4 holes on the edge of my mounting location. But it all worked out. I took some pictures of my install. Tell me how yall think I done.
Post edited by cam5860 on
How does it sound ?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Well I just finished up about thirty minutes ago. So I have not really had time to listen much yet. But the tweeters are much brighter thans last years model and the midbass has a pretty good punch to it also. Just not near as deep as the momo's. But actually thats better because the momo's make to much **** rattle in my truck like my side mirrors.
Really you don't want to much midbass. Thats what the sub is for. You Just want the midbass to blend in and the db's do just that.
I also bought a polk audio DB104 to go with this system. But I have to get my box built first. I'm going to get my local car audio shop build it. Because they built one for me in the past and it fit like a glove. Could keep the seat all the way back.
Yeah, you kinda do want a lot of midbass. Having weak midbass will pull the sub to the rear a ton due to them not blending well. Having good strong midbass allows you to cross the sub over lower and make it seem much more up front.
To keep your doors from rattling, youll have to deaden the door trim panel. Best way is with a layer or Dynamat (or your any other quality brand) then lay a layer of foam or quilt batting or some other soft material on the inside to keep the hard plastic from vibrating against the door panel.polkaudio sound quality competitor since 2005
So your saying with stronger midbass! I could cross my sub over at say 50 hertz instead of the usual 80 hertz? Trying to get all the rattles out is almost impossible with the momo's they have so much midbass. I think I'm going to enjoy these DB's much better because they have decent midbass, but not so much that it causes window cranks and side mirrors to rattle like hell.
I finally got my sub box built for my DB104. But I run into a few problems. After I built the box it was not deep enough for the sub. It was a 1/2 inch to shallow. So I had to build a plate for it. It don't look to bad. Better than I thought it would look. Far as the sub it's sounds better than I thought it would. I cannot believe how hard this suck hits. Shocked the hell out of me.
Good looking box there dude. Attaboy.polkaudio sound quality competitor since 2005
Sharp, clean install... my compliments, it looks great! What's the truck btw?MacLeod: I guess youre lucky Polk has such lax hiring standards.
Josh: Damn skippy! -
I love the install good work, if only my car was that easy.2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
where did you get those spacers?Dodge Dakota
HU: Pioneer
Amp: Profile AP600 & Phoenix gold r2.5:2
Speakers: Boston SX 6.5 components
Subwoofer: polk mm2104 -
Joel it's a 2000 S-10 pickup regular cab.
I just cut another piece of 3/4 plywood for my spacer. I could of just made a ring instead of a plate. I had planned to cut another whole piece to go all the way across the front. But I would of had to move my seat up one notch to do it. I did not won't to sacifice leg room to make it look perfect. So I just cut a square out for the size of the woofer.
Without the spacer my bottom mount depth is 5 inches. With the spacer it is 5 3/4 inches. The polk DB subs require 5 1/2 inches of depth to install.
what did u use to make the hole for your tweater?2013 Toyota Prius
Mosconi 6to8 v8 -
A 2 inch Hole saw is all you need to make a perfect cut.
im gonna try that out on my door, thanks.2013 Toyota Prius
Mosconi 6to8 v8
