Is this just a tad bit esoteric ?
mrbigbluelight
Does this item belong in the land of "Audiophile Wall Plate Covers", or am I missing something ?
http://cgi.ebay.com/Versalab-Wood-Block-to-Reduce-RF-Interference_W0QQitemZ250167464132QQihZ015QQcategoryZ3280QQssPageNameZWDVWQQrdZ1QQcmdZViewItem#ebayphotohosting
Versalab Wood Block. Outstanding audio accessory to eliminate or dramatically reduce radio frequency interference (RFI) when plugged into your electronic audio components. The wood block plugs directly into your amplifier, preamplifier, cd player, etc. and the powercord plugs into the wood block. Retails for $200. Stereophile recommended component.
No Reserve! Great Low Price! Bid to own this essential high end audio accessory. Please don't hesitate to ask any questions you may have. Thank you for looking and good luck bidding.
Let's see: at $107.04 per component (amp, pre-amp, tuner, SACD player, DVD player, TT, Spring Reverb), that comes to ..... $749.28.
Okay .... I guess that's a good deal for a power cord running through a block of wood.
:rolleyes:
:rolleyes:
Post edited by mrbigbluelight on
must be from a magical tree...!!!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
I think Russman has sold a few of those in the FM.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
I see a ferite on the cable. That will help block high frequencies from getting on the cable. The wood shouldn't do anything with high frequencies (or low frequencies). I'm not sure what the intent of the wood is unless there is a big ferite inside and the wood is just a box to cover it.Vinyl, the final frontier...
I've still got those skyhooks for resonance damping for sale........anybody?
I tried my left handed cannooter valve, but still no compression...:DCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
Ummm, I don't remember reading about that in Stereophile and I sure would have.
hearingimpared wrote: »Ummm, I don't remember reading about that in Stereophile and I sure would have.
Try Audiophile. -
I bet there is something like a Corcom or similar AC line filter inside the wooden case.The wood looks like it is in 2 halves.Testing
Testing
Testing -
Like this http://www.corcom.com/Series/IEC/EASEBS/.Testing
Testing
Testing
