Is this just a tad bit esoteric ?
mrbigbluelight
mrbigbluelight Posts: 9,878
edited September 2007 in Electronics
Does this item belong in the land of "Audiophile Wall Plate Covers", or am I missing something ?
http://cgi.ebay.com/Versalab-Wood-Block-to-Reduce-RF-Interference_W0QQitemZ250167464132QQihZ015QQcategoryZ3280QQssPageNameZWDVWQQrdZ1QQcmdZViewItem#ebayphotohosting
Versalab Wood Block. Outstanding audio accessory to eliminate or dramatically reduce radio frequency interference (RFI) when plugged into your electronic audio components. The wood block plugs directly into your amplifier, preamplifier, cd player, etc. and the powercord plugs into the wood block. Retails for $200. Stereophile recommended component.
No Reserve! Great Low Price! Bid to own this essential high end audio accessory. Please don't hesitate to ask any questions you may have. Thank you for looking and good luck bidding.
Let's see: at $107.04 per component (amp, pre-amp, tuner, SACD player, DVD player, TT, Spring Reverb), that comes to ..... $749.28.
Okay .... I guess that's a good deal for a power cord running through a block of wood.
:rolleyes:
Post edited by mrbigbluelight on
  • beardog03
    beardog03 Posts: 5,550
    must be from a magical tree...!!!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • AndyGwis
    AndyGwis Posts: 3,655
    I think Russman has sold a few of those in the FM.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • madmax
    madmax Posts: 12,434
    I see a ferite on the cable. That will help block high frequencies from getting on the cable. The wood shouldn't do anything with high frequencies (or low frequencies). I'm not sure what the intent of the wood is unless there is a big ferite inside and the wood is just a box to cover it.
    Vinyl, the final frontier...
  • lightman1
    lightman1 Posts: 10,796
    I've still got those skyhooks for resonance damping for sale........anybody?
  • beardog03
    lightman1 wrote: »
    I tried my left handed cannooter valve, but still no compression...:D
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • hearingimpared
    hearingimpared Posts: 21,136
    Ummm, I don't remember reading about that in Stereophile and I sure would have.
  • lightman1
    Try Audiophile.
  • Systems
    Systems Posts: 14,873
    I bet there is something like a Corcom or similar AC line filter inside the wooden case.The wood looks like it is in 2 halves.
    Testing
    Testing
    Testing
  • Systems
