dynamat
eloplayspolo
Dynmat CAN short a speaker connection if it is touch both positive and negative correct?
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
Mosconi 6to8 v8
Post edited by eloplayspolo on
I believe the foil covering can be conductive...
Mac, Cody ?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Ya know, Ive never thought about it but it is an but it is an aluminum backing so I would say yes it could be possible.polkaudio sound quality competitor since 2005
well i mean its on my rear deck, and my speaker is pushed through the hole Tight as a virgin on prom night, which is a good thing of course, just the speaker doesnt play music when i connect it to the head unit, so im thinking thats what it is.2013 Toyota Prius
Mosconi 6to8 v8 -
Clean out the area around the speaker connections...Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
lol thats what i was planning on doing, dont sass me. BUt i wanted to make sure that it WAS possible for dynamat to short out a speaker.2013 Toyota Prius
Mosconi 6to8 v8 -
I did not want to take a chance, so I always made sure that the area around the connections were clear of at least the foil part.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
YES! It is absolutely conductive.
word to your mother.
Thought of the day kids:
Yes, metal is conductive...yay!
and on a side note, it is also a bad idea to put it in the microwave to heat it up, just in case you were wondering.
exalted512 wrote: »and on a side note, it is also a bad idea to put it in the microwave to heat it up, just in case you were wondering.
-Cody
So much for my plans of dynamatting this winter
MacLeod: I guess youre lucky Polk has such lax hiring standards.
Josh: Damn skippy! -
hahahaha thanks. Too bad Southern California Sunshine > than winter when it comes to dynamating.2013 Toyota Prius
Mosconi 6to8 v8 -
When I was doing my floor in the winter, I would start the truck and put my damplifier under the hood to heat it up.
I've used my heatgun before.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
a heatgun will be fine, as it will make the mat more malleable. However, I think what exalted512 was getting at is that the alluminium in the microwave would cause that arcing seen when putting metallic items in
anyone ever dry the dish washer on the pots and pans cycle2013 Toyota Prius
Mosconi 6to8 v8 -
I know.... I was stating what esle will work.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
I was making the joke that I was planning on using my microwave to heat dynamat for a winter install....
Josh: Damn skippy!
![[Deleted User]](https://forum.polkaudio.com/applications/dashboard/design/images/banned.png)
