Only one compotent hook up
Home Theatre
Home Theatre Posts: 469
I am getting a cable box on Saturday. I also have a hd-dvd player.
I have a old big screen tv that I bought in 2002. The problem is I only one
compotent 1080i hook up. The other two are for 480 i or 480 p.
I want both of them hooked up to the 1080i. Any suggestions? would you run the compotents the receiver. How would you hook this up?
Everything I own burned in the fire!!!!!!!!!!
Post edited by Home Theatre on
  • lightman1
    lightman1 Posts: 10,796
    edited September 2007
    Take a look at your local Wally-World Radio Shack or, if you want to pay more for the same, Your local high-end haunt. There are some component switchers around on the cheap. And some are even remote controlled if you want to add another to the coffee table clutter. Give it a shot.
    Russ the Lightman
  • Home Theatre
    Couldn't you just run the compotents through the receiver???????
