Your opinions- best sound deading choice.
Pantocrator
Pantocrator Posts: 84
edited September 2007 in Car Audio & Electronics
I tried searching, but my effort was fruitless. I am looking into sound deading my car as much as possible, but I would not like to kill my gas mileage with weight. I have looked into second skin, dynamat, and I've heard of raammat and b-quiet and e-dead (something like that??).
What are your opinions of these? How much do you actually need? So far, I feel that dynamat is overpriced, and second skin has a very helpful guide/site. Any help, as always, is appreciated.
Stratus 4 door, btw
My system (thanks to everybody for the help)
One pair Polk SR6500 comps
One Polk SR124DVC sub
One Pioeer Premier 880PRS HU
One Memphis belle 16MCH1300 amp
Post edited by Pantocrator on
  • Pantocrator
    edited July 2007
    What did that cost you?
  • exalted512
    exalted512 Posts: 10,734
    edited July 2007
    If youre looking to save weight, so with second skins liquid stuff.
    -Cody
  • 300m
    300m Posts: 28
    edited July 2007
    Team Schil Acoustics
    ’05 MECA world champion
    ’06 MECA world champion
    ’06 MECA Culbertson cup (best of show)
  • monologuist
    monologuist Posts: 40
    edited July 2007
    would recommend Raammat and Ensolite combo. Best price/performance ratio.
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited July 2007
    Second Skin makes solid products at very reasonable prices.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • Pantocrator
    edited July 2007
    Besides weight, what is the difference between second skin's sheets vs paste? Is there a performance/price difference?
  • MacLeod
    MacLeod Posts: 14,358
    edited July 2007
    Im a Dynamat Extreme man myself. It works just as well as the others and is a whole lot eaiser to get.
  • 1996blackmax
    edited July 2007
    With SecondSkin I just put my order in....few days later it's at my door. How much easier does it get? Besides, with the money I save, I can get more deadener...or go to the movies...or get some nice thick steaks :).
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • exalted512
    edited July 2007
    MacLeod wrote: »
    I can order my second skin naked and pick it up at my door in boxers...I've done it before.
    -Cody
  • exalted512
    edited July 2007
    Actually, the sludge and spectrum stuff are less money per sq foot than mat. The down side is you have to wait for it to dry. Its not a long wait by any means though. My truck is a daily driver that I use for work 6 days out of the week, and my entire interior is done in mat AND liquid.
    -Cody
  • Pantocrator
    edited August 2007
    Bumpamanjaro.
    How many feet would you recommend? Right now I am thinking of doing the doors and maybe part of the trunk. How many more places should I put it.
    Off topic but also important. Back to my subwoofer grill problem. Can someone tell me the exact problem with the SR subs and MOMO grills If it is clearance I think I might raise the grill using some wood, but I need help with knowing what the problem actually is.
  • exalted512
    edited August 2007
    For a stratus, Id get about 80^2 ft. Doors and trunk are the two main things. Get your rear fender wells really good as well. License plate and trunk lid are a bad source of rattling. Do you have the subs in there already? Notice any bad resonances already?
    If the grill fits, then I guess the only thing is the clearance. Get a dremel and go at it.
    -Cody
  • denim
    denim Posts: 79
    300m wrote: »
    Don did an awesome job with that, I will probably order Raamat because of his test.
  • ilikesound
    ilikesound Posts: 355
    i just did my second skin's third step (sound foam) and ill just say that i can't really notice a difference between dynamat and second skin (other than the outrageous prices that the dynamat goes for.) i couldn't be happier!
    At Home:
    Panasonic 42'' TC-L42U12 LCD
    Pioneer VSX-80TXV
    Toshiba HD-XA2
    Sony PS3 - psn "metalguitars"
    Xbox 360 - gamertag "giggidygiggidy"
    Panamax 4300EX
    Polk RTi8's
    Polk CSi3's
    Polk FXi3's. (x2)
    Martin Logan Dynamo (x2)
    Audioquest interconnects and wires.
    Away From Home:
    JVC HDR-50
    stock system in new car for now:(
  • ilikesound
    btw, the second skin spectrum ("paste" as it were) and the dynamat-esque material, are geared towards preventing seperate frequencies. when used together they create an almost impenatrable barrier for sound of that specific frequency. i can't even hear my magnaflow exhaust in my accord now, it used to be ALL OVER the dang place too..
    At Home:
    Pioneer VSX-80TXV
    Toshiba HD-XA2
    Panamax 4300EX
    Polk RTi8's
    Polk CSi3's
    Polk FXi3's. (x2)
    Away From Home:
    JVC HDR-50
