FS: Tyler Linbrook Signature System
Ricardo
Ricardo Posts: 10,636
edited September 2007 in For Sale (FS) Classifieds
**SOLD**
I'll probably get flamed for this, but here's the link to the FS add in Audiogon. My last sale didn't get any takers here anyway, so at least doing it this way I save some time posting only one add.
10% off for Club Polk members.
http://cls.audiogon.com/cgi-bin/cls.pl?spkrfull&1194492765
SOPA
Post edited by Ricardo on
  • beardog03
    beardog03 Posts: 5,550
    Those are beauties !
    Good luck with your sale...I`m sure they won`t last long
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • McLoki
    McLoki Posts: 5,231
    Remember this about the Tylers???
    HTrookie wrote: »
    That's right; you can write it down; today, June 5 2007, I am saying that I will not upgrade speakers or components. I leave the door open though for maybe experimenting with cables/wires....and...maybe, a little something here or there for a second rig
    I'm not going to make this long, just a couple of key thoughts:
    1.-Everyone needs to hear a pair of Tyler full range speakers.
    2.-Good Solid State amps beat tube amps
    3.-No matter how small your room is, treatments can make it sound incredibly good and open.
    Do I get a refund on all the paper wasted by taking notes about you being done and you keeping your current speaker of the month forever?? :D:):D
    What direction you heading? (and good luck with your sale...)
    Michael
    Edit - nevermind - Just saw your thread about the thiels. Congrats on the new speaks. I hope to hear your current system (whatever that may be at the time) at least once before you thow up your hands and just hire a band to play in your basement when you want to listen to music.... :)
  • Ricardo
    McLoki wrote: »
    "That's right; you can write it down; today, June 5 2007, I am saying that I will not upgrade speakers or components."
    Michael,
    Well, I am actually "downgrading" if cost is the measure here...so that statement stays valid :):)
    SOPA
  • beardog03
    those look to be some fairly large speaks..!
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • Early B.
    Early B. Posts: 7,900
    HTrookie wrote: »
    Michael,
    Damn. That's almost a valid technicality. However, you actually upgraded by downsizing.:p
    "God grooves with tubes."
  • rskarvan
    rskarvan Posts: 2,374
    Audioholics:
    The first step is to admit that you have a problem....
  • Ricardo
    What problem?
    SOPA
  • Ricardo
    Retail $9,000
    Factory direct (New speakers) $6,500 (You can call this the list price, since Tyler only sells direct as far as I know).
    Tyler sells used speakers between $4,000 and $4,500 depending on finish.
    I bought them used directly from Tyler.
    SOPA
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    And as always, Ricardo is asking for far, far less than the average seller.
  • Early B.
    This is a screamin' deal. Been watching 'em on the 'gon for a while, and $4K is a good price for these speakers, so less than $3K for Polkies is a giveaway.
  • madmax
    madmax Posts: 12,434
    If I were not in search of some horns I would be right on these.
    madmax
    Vinyl, the final frontier...
  • Early B.
    madmax wrote: »
    madmax
    Put your horns on hold, max, and jump all over these. I'd love to hear what you think about them on your system.
  • SolidSqual
    SolidSqual Posts: 5,218
    What kind of electronics do you need to run these babies? What's the life expectancy like? Do they hold together?
  • Ricardo
    They are pretty easy to drive; 4 ohms but relatively efficient at 92 db. Of course the 200WPC minimum applies if you want to make them sing their best.
    They are very solidly built; If IRC cabinets are 1" thick. They are 130 lb each. Drivers are SEAS, which as far as I know have good reputation. Crossovers have no circuit boards, and top notch components. Finish is superb. Yes, they will last many many years.
    SOPA
  • stubby
    stubby Posts: 723
    Just thought I would chime in and say that if anyone here has ANY reservations about buying something from Ricardo, rest assured. He is a class act all the way.
    Paul
    SRS 3.1TL
    Harman Kardon Citation 5.1
    Anthem AVM2
  • Ricardo
    Hey Paul; thanks for the comment. I must say that when we did business I had no other option....I opened the door and there were two big 6' 10 guys standing there....I had to be complacent ;)
    SOPA
  • engtaz
    engtaz Posts: 7,654
    What are you looking into as far as speakers that will replace the Tylers?
    engtaz
  • Ricardo
    SOPA
  • Ricardo
    Sold.
    SOPA
