were can i get replacement speaker fabric??
n_e_w_d_u_d_e
hey guys. I found some vintage polk audio speakers from a pawnshop, and the speakers were in great shape but would still like to do a little spit shine on them. I would like to put some new, I'm not sure what you call it, but the speaker fabric covering the speaker in the front. The part you can remove to see each individual speaker in your speaker. The fabric covering the speakers look a little faded and worn so adding some new fabric would make it look so much better. Don't know who owned them before but who ever it was took great care of them because the speaker wood casing looks almost new. I hope i can continue in keeping them look good. Also, what kind of a substance or cleaner could i spray on the speaker wood casing to give it a little shine and protect it. Thanks again.
Post edited by n_e_w_d_u_d_e on
partsexpress.comDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
partsexpress.com
what is the material actually called. I'm on the website and was wondering if its what you call "Grill Cloth"?? -
Ask Darqueknight where he got his. He says it is truly acoustically transparent.
hearingimpared wrote: »Ask Darqueknight where he got his. He says it is truly acoustically transparent.
okay will do? Can i just send him a private message through the forums?? And thanks for the help on finding the item guys. -
n_e_w_d_u_d_e wrote: »okay will do? Can i just send him a private message through the forums?? And thanks for the help on finding the item guys.
Yes.
