oil injected cables
JimBRICK
Are these just a gimmick? Or is there validity in this
http://cgi.ebay.ca/OIL-INJECTED-AUDIO-RCA-CD-Tube-Amps-Sound-12mm-CABLE_W0QQitemZ330160996749QQihZ014QQcategoryZ64591QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.ca/GOLD-OIL-INJECTED-TUBE-AMPS-SOUNDING-CD-CABLE-FOR-LINN_W0QQitemZ300147091737QQihZ020QQcategoryZ64591QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
two examples I found
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Under construction
Post edited by JimBRICK on
Would definitely suck if someone cat bit into those things, hahahha
or
If the connector wore out, I'd be afraid they would break and leak all over my components.
This is assuming oil is actually injected in there.
Looks cool though- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
At least they are admitting it has snake oil in it.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
If you had an efficient manner of keeping all the individual strands separated and not touching while one bends it around the back of the gear and/or to the speakers this makes sense electrically. Medium voltage and higher (greater than 69kV) underground transmission cables use oil to insulate the cable due to the high potential.
For speaker cables and IC's, I'm gonna go with mostly snake oil on this one.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
They are made from dead anchovies.Michael
NORTH of 60° -
I wonder if you have to change it after 3000 miles?
I can already hear the debate now...
"Yeah, I use Mobil-1 synthetic in my cables. Synthetic oil just sounds cleaner than natural oil. I use 0W20 in the winter, but then swap in 5W20 in the summer..."
/COLOR] [U][URL="http://www.polkaudio.com/forums/showcase/view.php?userid=68366"][COLOR="Blue"]My Rigs[/U][/COLOR][/URL] [COLOR="Red" Balanced Audio Technology | Revel | Dodd | Monarchy | PS Audio | MIT | Polk | Etc. -
Maybe there will be a "green" version made from biofuel sources.
what about a k-y version for the kinky people2 CHANNEL
Under construction
