Using acenters as mains
joeygrand3
joeygrand3 Posts: 41
I would like to know if I can use center speakers as mains. I am thinking about using two Polk CS1s as main speakers. I presently have a Polk CS2 as my center, and Polk m30 for my mains. If feasable, I would use two cs1s(I have a spare cs1,so I would need to purchase another one.)as my main speakers and place the m30s as my rear surrounds. The reason I thought this might work is that the Polk cs1s appear to have the same configuration as the Polk M40s. I`m just not sure about the crossovers and the quality of sound. Thanks for any advice on this subject.
Post edited by joeygrand3 on
  • honda cber
    honda cber Posts: 267
    edited September 2007
    well, no real reason you cant do it, but you will probably want to stand them on end, which might look a little funny. i would think that imaging would be negatively affected by placing them horizontally.
    a
    gear list:
    1 down, 4 up....
  • engtaz
    engtaz Posts: 7,669
    The only problem I see is getting the woofer freq sound maybe limited.
    engtaz
  • cfrizz
    cfrizz Posts: 13,415
    It will be extremely limited! Back when I had the Parasound & an Outlaw Mono driving my fronts & center, I would sometimes forget to turn on the Parasound. So just my center was playing. It basically had no bass!:eek:
    So I wouldn't recommend it.
    engtaz wrote: »
  • honda cber
    well, CS1 has not much worse response in the low-end than the monitor 40's he was comparing to. 65Hz (-3 dB) to 57Hz (-3 dB) for the 40. he didnt mention a sub, but i assumed he would be using one. i mean, i use a sub with floorstanders.
    a
    gear list:
    1 down, 4 up....
