Power cord question!
hamzahsh
hamzahsh Posts: 439
I have a Yamaha RX-V1400 receiver and it has a 2 pin detachable power cord and I want to upgrade it to a high-end thick power cord, but my problem is all the high-end power cords I've seen on net have 3 pin IEC connector, my question is, is it safe to use 3 pin IEC power cord instead of 2 pin cord.
:confused:
Panasonic TH-50PX80U Plasma HDTV
Polk Audio RT800i (fronts)
Polk Audio CS400i (center)
Polk Audio F/X1000 (side surrounds)
Polk Audio RTi6 (back surrrounds)
Velodyne CHT-15 (subwoofer)
Yamaha RX-V1400 (Pre/Pro)
NAD C272 (2-ch Amp)
Adcom GFA-7605 (5-ch Amp)
Toshiba SD-3109 (DVD/CD player)
Malata DVP-580 (Multi-region DVD player)
Post edited by hamzahsh on
    F1nut Posts: 51,710
    edited September 2007
    The IEC plug end of a 3 wire cord will not fit the C7 socket of a 2 wire connector. PS Audio sells a nice power cord with a 2 wire C7 plug.
    F1nut Posts: 51,710
    No, they are right on the money.
    F1nut Posts: 51,710
    Don't make me hurt you, Sal. ;)
  • RaysR6
    RaysR6 Posts: 28
    Is it really that big of a deal?
