Computer Music to Receiver Output
FittyFieFo
I've got my computer hooked up going to the receiver. Every time I want to use my receiver to play the music from my computer, I turn it up loud and hear a loud buzzing noise. What is the cause of this!? Feedback? How do I lessen this noise?
Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
Pre-Amp: Marantz AV7005 | Amp: Emotiva XPA-5 | Speaker wires: Signal Cables | Interconnects: Signal Cables
Post edited by FittyFieFo on
http://www.xitel.com/USA/prod_hflpc.htm
OR
http://www.xitel.com/USA/prod_gli.htm
Does anyone know if this product works and will solve my problems?Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
Pre-Amp: Marantz AV7005 | Amp: Emotiva XPA-5 | Speaker wires: Signal Cables | Interconnects: Signal Cables -
Fo, I've used a Xitel HiFi-Link for several years to feed the digital USB output from a laptop computer to one of my receivers. The main usage is stations listed on this site which stream classical music from the U.S. and all over the world. Although streaming audio isn't of the highest quality, of course, the Link does its job without any problems.
As to the buzzing noise that you're experiencing, it isn't likely that it's the result of a ground loop, which most commonly appears as a hum. If the buzzing is due to using an analog output from your computer which is contaminated from the noisy computer environment, then the HiFi-Link would solve the problem, since it uses a digital output which isn't affected by the noise. However, it isn't certain that the buzz is actually due to that, so that result isn't guaranteed . -
What's the difference between the humming and buzzing noise? How do I figure if it's analog or not? I know my monitor is digital...and my computer is prolly the main problem for noise..Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
Suggestions on product?Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
How about trying a different cable or getting a card with a optical/digital out?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I kinda don't want to do that... I mean my sound card seems to be somewhat decent without any digital output. I'm using a Monster Cable too to connect my computer to receiver (with many regular headphone jack extensions)Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
I used a monster cable with a mini on one end, RCA's on the other, it was junk.
I have the silver version of this cable.
http://signalcable.com/analogmini.html"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
my sound card has an 1/8" audio output and I used an 1/8" to RCA adapter to a patch cord into an aux input on my preamp. My PC was in another room and the cable was easily 40' long. there was no audio quality problem, signal degradation, noise, hum, etc. check to see if you have such an output.
the down side of this arrangement for me is since upgrading to a new preamp I don't have a spare set of inputs available any longer. i've been looking at switch boxes but everything so far seems of questionable quality. I do miss not having the PC connection anymore. I especially miss Pandora.com with its customizable radio station and all the music I (mostly) hadn't heard before.The Beloved System:
Parasound Halo P3 Preamp
Parasound Halo T3 AM/FM Tuner
Grant Audio Tube Buffer
ADC Sound Shaper II IC Graphic Equalizer
Polk XRT12 XM Satellite Radio Receiver
2 Carver TFM 35x Power Amps
Harmon Kardon T45 Turntable w\ Benz MC 20E Phono Cartridge
Vincent Phono Preamp (not enough gain in the Parasound Phono In)
Cambridge Audio 640C V2 CD Player
Nakamichi BX300 Cassette Deck
Polk RTi 12 Main Speakers
2 Polk PSW 1000 Subwoofers -
Thank you for your input, I'm going to research on this some more. I emailed the guy from that one website with the HI-FI site, he responded to me with this:Hi Scott,
That sounds like you've got a ground loop issue there. Here is a great website that explains why this is occurs:
http://www.epanorama.net/documents/groundloop/home_solving.html
and how to fix it:
http://www.epanorama.net/documents/groundloop/audio_isolators.html
If you do have a ground loop, our GLI will help cancel the hum that you're getting while maintaining full frequency response (some ground loop isolators result in a big reduction of the frequency response which is no good for high fidelity audio). The HiFi-Link will not cut the hum with a ground loop involved.
Best Regards,
Xitel Support.
I've read both articles, and yet..I left confused...Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
I had the same problem I was using a soundblaster audigy soundcard I had a hiss hum when I hooked it up to my rig. I decided to upgrade the soundcard to the m-audio delta 1010lt http://www.m-audio.com/products/en_us/Delta1010LT-main.html
WOW!!!! what a difference no hum no hiss with nothing playing I can turn the volume all the way up dead silence no hum no hiss. keep in mind I never changed cables just the card.
The next thing I noticed was the HUGE difference in sound quality, I have now unhooked my cd player and play all my cd's though my pc the SQ is that much of a difference. It sounds like I spent $5000 on new speakers and amp its that much of a diiference I highly recommend anyone who has their pc hooked up to their rig to invest in a good sound card you will be amazed.TV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX -
Okay this is were i will shine lol Hear is what is happoning what your computer does is take the ac electric current that you feed it and transfers it into dc then feeds it "unfiltered" to all your componets in you computer and to make matters worse is if you have built in audio card "meaning the its in the motherboard" now there are some ways to clean it up the first is to to not use something like usb. a Y adaptor that transforms 3.5 headphone jak to rca conectors or believe it or not dont use fiber optic. What instead you want to use is coaxal or on the back of your computer it will be something called SPDIF it stands for sony and philps digial inital frequency. but is just coaxal. The second thing is if you can get a NEW sound car that has a coaxal out believe me its worth it. The final thing is make sure your importing your music in at least 256kbps if not better I have a setup and i use 256 and my reciver is a yamaha rx-v361 with suround sound. hope this helps if you have any more questions email me nightmarecivic@gmail.comHT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
