Subwoofer Help
MJD
Does anyone think the PSW650 is better than the PSW404 ?
The PSW650 has less wattage than the PSW404 but (2)10" drivers. I currently have my PSW404 volume set a 3/4 the way up (3 o'clock) to get the Bass I want, is this OK??
Any recommendations would be appreciated
Thank you
Thank you
Post edited by MJD on
3 o'clock is a little bit above, but it won't hurt your sub.. some rooms need a little more umph to get decent sounds. where is your sub in the room? putting it in a corner will increase the sound a bit.PolkFest 2012, who's going>?
The volume setting on the sub amp is pretty much meaningless.
The total signal input to the sub is a combination of the pre-out input strength and the volume control setting on the sub amp.
It is quite possible to overdrive a sub with the volume set at 1/4.
You didn't give us enough info for the whole picture."What we do in life echoes in eternity"
Ed Mullen ([email protected])
SVS -
The sub is in a corner, for music I prefer it at about the 1 o'clock position and mainly 2 for movies, my room is 25 x 12 and the floor is 16" stone tile. My receiver is set to subwoofer 0db and only goes negative not positive. -
I would say if you sub level at the receiver is max'ed out and your sub amp volume is at 3/4, and your room is that large, then you are probably over driving the sub.
Only way to tell is calibrate the system with an SPL meter and test tones/calibration DVD. If the sub is running way hot with your current settings, you have your answer for sure."What we do in life echoes in eternity"
SVS -
Thank you for your help!!!, The Amp is not running hot & if I go to the 1/2 way mark the sub outputs very little bass, do you suggest a larger sub like the PSW650?? lower wattage but dual 10" -
I suggest system and sub calibration with an SPL meter and test tones/calibration DVD. I suspect you are running the sub hard, but that remains to be seen."What we do in life echoes in eternity"
SVS
