Brrrrrrrrrrrrrrr.......
shack
shack Posts: 11,154
edited August 2007 in The Clubhouse
Time to break out the thermal underwear, sweaters, hand warmers and load up the fireplace with wood....It has finally dropped below 90° for the first time in 31 days....a record for East Tennessee.
  • madmax
    madmax Posts: 12,434
    edited August 2007
    Frostbite gets you before you realize...
    madmax
    Vinyl, the final frontier...
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited August 2007
    You forgot the hot chocolate
  • Early B.
    Early B. Posts: 7,900
    edited August 2007
    Blame it all on global warming...
    "God grooves with tubes."
  • bobman1235
    bobman1235 Posts: 10,822
    edited August 2007
    Only vaguely related, but leaves are changing around here already. Almost a full month early. It's been really dry, so I suspect that's the culprit, but it makes it feel like it's almost October, instead of almost September.
