adcom 5500 amps
tom t
tom t Posts: 543
edited September 2007 in Electronics
guys,
on tha adcom 5500 amps, in noticed some have a detachable line cord and othere hav a fixed one. which is the newer amp. also the four trim pots between the speaker post,what are they for??? no mention in the owners amnual thanks
Post edited by tom t on
    heiney9 Posts: 25,432
    edited August 2007
    tom t wrote: »
    guys,
    Detachable are slightly earlier versions. Those aren't trim pots they are power supply rail fuses (2) for each channel. The detachable P/C version is the slightly more desireable version IMO.
  • tom t
    tom t Posts: 543
    edited August 2007
    thanks heiney9, any problems with these amps,or are they reliable??
    edited August 2007
    Dead reliable if not abused by the prior owner(s).
  • tom t
    tom t Posts: 543
    edited August 2007
    thanks, they seem to be a good buy on the used market. i see anywere from $350--$500. not bad at all. i dont need them,but at that price how can you go wrong. its a cheap way to try something new and see if its an improvment over what you have now
    edited August 2007
    tom t wrote: »
    I agree. There was one on Audiogon for $395 recently which is an insane price for a $1200 retail amplifier. Almost pulled the trigger twice just to try it out. I still have my trusty 545 which just hit the 20 year old mark. Thought I'd give the newer Mosfet version a try but it's more of a distraction as I'm looking to move a notch or two above the Adcom series. But the price was attractive and I have no doubt they are great performing amps.
  • tom t
    tom t Posts: 543
    edited August 2007
    sometimes moving a notch up dosent work out. been there,done that. while we are on the subject what about the 5802 amp. that one seems to be a brute. have you heard anything on them. i could of picked one up for $700. what a good price.
  • tom t
    tom t Posts: 543
    edited August 2007
    i saw that one on a-gon. that was a good price,a few weeks back
    edited August 2007
    tom t wrote: »
    If I can't make either a Pass Labs, Monarchy or Classe work with my SDA's my next top choice is the 5802. It is a brute but it has tons of finesse as well. I've owned Adcom for so long I really want to try something different not nec because it's going to be better, just different. However an NP Alpeh or "X" series is a couple notches better. I'm really looking to go with an Aleph series amp right now. I have great respect for Nelson Pass design's because he gets the simpler is better approach better than anyone.
    I look at the guts of some of these other amps and just shake my head at all the "crap" in there. Even my 545 is simple clean and really only has 3 gain stages.
  • tom t
    tom t Posts: 543
    edited August 2007
    pass labs is good stuff for sure. another amp that seems to be a big brute is the parasound 3500. i just missed getting one on a-gon unless the deal falls through. i think it would drive anything without breaking a sweat. i even hear the rotel 1090 is a tough cookie also. a good review from stereophile,no less. they and be had for about $1,200,not bad. amagine 380 wpc or 700wpc into 4ohms.
  • tom t
    tom t Posts: 543
    edited August 2007
    dude heiney9,
    i just picked up a 5500 for $400. an older one with the detached line cord in mint cond. lets hope that bad bot works as good as it looks when it gets here
  • tom t
    tom t Posts: 543
    heiney9, i inquired to adcom about the 5500 amps and the detachable line cords. they emailed back saying the detachable line ones are the newer mopdels. they been doing them this way for about 7-8 years now. so differend cords can be used for international markets. now i feel better, the amp i just picked up is newer.
  • Dave38
    Dave38 Posts: 101
