What wires do i need and from where?
mod220
i'll be hooking up an entire HT soon. tv, reciever, amp, dvd, 2 front, 2 rear, 1 sub, 1 center channel. can anyone break down what i need and where you recommend i buy it...wires, power cords, etc...thanks in advance!
Post edited by mod220 on
I use THX Monster Standard interconnects. These are available online thru amazon or just about any decent local retailer. Lots of choices out there for these types of cables so it just depends on how much you are willing to spend. These cables work well for me but there are some that are even better. As far as speaker wire, I use a relatively inexpensive standard 12 gauge with banana plugs.
Check out this read on speaker wires.
http://www.roger-russell.com/wire/wire.htm#thetruth
I would recommend a quality surge/power center for your system. I'm using a Monster Cable MP HT-800. Check out this guy here on ebay. He's got some decent/inexpensive ones that could do the job for you.
http://stores.ebay.com/Cable-Closeouts_Monster-Products_Monster-Power-Centers_W0QQcolZ4QQdirZ1QQfsubZ11474626QQftidZ2QQtZkm
Again, there are others that are better and more costly. But from my experience, the HT-800 works fine.
Have fun and good luck.
I smell trouble brewing.................;) -
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
I would recommend anything but Monster.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I second signal cable. And . . . to prove that speaker wire does matter, you could try buying the top speaker wire from Blue Jeans Cable(another respected name around here) and the Ultra Speaker cable from Signal Cable. I gurantee you will hear an obvious difference.
Both Brands are good, but Signal is more near the high-end. -
In reference to people who believe good cabling is nonsense, I have a theory. These people want to justify in their minds that they don't need the quality interconnects and speaker wire because they don't have the money to otherwise afford them. I'm not saying cable prices aren't outrageous, but I am saying a $200 investment of cabling from Signal Cable, will blow the best Blue Jeans cable of the same length out of the water. In the world of high-end $200 bucks is laughable.
I have Signal's Ultras and can't say enough good things about them.
As for interconnects, I'm a big fan of Alpha Core's Silver Micro Purl, but they're $$$.
It all comes down to what you can afford."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
www.bluejeanscable.com
Well made cable that goes on & of like a dream. Fast shipping & reasonable prices.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Buy what you can afford. Signal is very good for the money, with great customer service.
You will need:
-RCA interconnects from your receiver to your amp (one per channel)
-Speaker cables from your amp to your speakers.
All components will bring power cords; get started with those, and down the road you might want to try upgrading.
For DVD & TV it depends on the input/output options you have in your TV, Receiver and DVD.
Most TV's have now HDMI input, though Most receivers don't. If your DVD has an HDMI output, you'll get the best picture quality by connecting directly from the DVD to the TV; if your receiver does have HDMI, you could connect DVD to Receiver and then receiver to TV, but it will require an extra cable. You will need then to connect audio from the DVD into the receiver; you can use a coaxial or optical cable.
You'll need to do a lot of set up in your receiver, best recommendation is to follow the manual.
Good luck._________________________________________________
The monster thx standard stuff is very good bang for your buck, they are well made, have tight gripping connectors, and some nice shielding. If you don't want to deal online I would say the THX stuff is hard to beat for bang for your buck, audio cables for $15/pr and component video for $30.
I would also recommend Heartland Cables and Blue Jeans Cables. I personally use Heartland Cables for most of my system, specifically Belden 89259 with Eichman Bullet Plugs. Dan is very easy to deal with and helped me out a lot when I first got into this hobby, if you look at the testimonials I am JR from CT.
Jared
