SDA SRS 3.1 bind post cup.
engtaz
Does anyone have the plastic cup that holds the pin blade and binding post for 3.1's? one of mine cracked? I just notice it when I went to bi-wire them.
engtaz
Post edited by engtaz on
If none are available, do I epoxy it or does some body have a better idea?
Thanksengtaz
Can you seal/epoxy it from the inside of the cup?That might get you thru(as long as it's sealed)until one pops up. Good luck.JC approves....he told me so. (F-1 nut)
