Need Help Choosing Right Amp
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2007
    So then take your time, keep saving money & keep an eye on Audiogon & get your matching Sunfire amp!
  • snow
    snow Posts: 4,358
    edited August 2007
    skipf wrote: »
    A year ago you might have gotten that TFM-55 for less than $300. Today I would expect that it will go much closer to $400.
    I really really doubt it will go for less than $500.00
    The average for the last 2 months on ebay is $697.75 for a TFM-55X
    REGARDS SNOW
    edited August 2007
    nikolas812 wrote: »
    All I care about is the quality of the music. I want the very best I can get with budget I have right now. I have absolutly no music right now without a amp. I just want to get a amp and set back and listen for awhile.
    If that is the case then,look for a used carver and be done with it untill you can get some scratch for the sunfire.Get some good 12 ga. speaker wire from home depot,decent and cheap.
