off air hd cutting out
ilikesound
ilikesound Posts: 355
edited August 2007 in Electronics
has anyone ever had an issue with off-air hd programs "digitizing"? the program will lose sound for a couple seconds, and the picture will seem blocky, and freeze for a moment or two. i am using a terk off air hd antenna with a mitsubishi 50''.:confused:
At Home:
Panasonic 42'' TC-L42U12 LCD
Pioneer VSX-80TXV
Toshiba HD-XA2
Sony PS3 - psn "metalguitars"
Xbox 360 - gamertag "giggidygiggidy"
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Martin Logan Dynamo (x2)
Audioquest interconnects and wires.
Away From Home:
JVC HDR-50
stock system in new car for now:(
Post edited by ilikesound on
  • texastown
    texastown Posts: 16
    edited August 2007
    When the picture pixelates and the sound breaks up it is the result of a weak signal or signal interference.
  • ilikesound
    edited August 2007
    right, that makes sense, but how do i fix that? i've seen people use those antenna's with flawless performance but i've never been able to do it myself. perhaps it's the area i live in?
    At Home:
    Pioneer VSX-80TXV
    Toshiba HD-XA2
    Panamax 4300EX
    Polk RTi8's
    Polk CSi3's
    Polk FXi3's. (x2)
    Away From Home:
    JVC HDR-50
    billbillw Posts: 7,448
    edited August 2007
    Are you using an indoor antenna or outdoor, roof mounted? If you already have outdoor, then a bigger/better antenna is needed, or a pre-amp maybe. If your using an indoor, then no doubt, you need something outdoor mounted.
  • GZ
    GZ Posts: 343
    edited August 2007
    Good advice from billbillw. We have a roofmount antenna (left over from our pre-cable days) and I'm glad I never crawled up on the roof to take it down. The whole township lost cable the other day during a bad storm, phone and roadrunner too. With the rotor on the antenna mast I was able to pull in local HD channels very clear.
  • ilikesound
    edited August 2007
    alright, thanks guys. ill head up on my roof tomorrow then lol.
    At Home:
    Pioneer VSX-80TXV
    Toshiba HD-XA2
    Panamax 4300EX
    Polk RTi8's
    Polk CSi3's
    Polk FXi3's. (x2)
    Away From Home:
    JVC HDR-50
  • thejck
    thejck Posts: 849
    edited August 2007
    watch when you put an outdoor antena on. your setting yourself up for lighting stikes. i think there are devices that can protect you against that
