RTA12Bs How to back off the high end??
geppy1
geppy1 Posts: 3,076
edited August 2007 in Vintage Speakers
I am getting attached to the RTA12bs. I may like them better then the SDA1s. Am I nuts??? After comparing tweeters I have decided on the Peerless for them (which is how they came from the factory 1981) but how would I back them off intensity wise just ever so slightly? I do not want to roll them off just back them down a hair. A resistor or longer and larger wire from the crossover? the stock ones have been cut several times and are shorter then they were.? Thanks,keith
Post edited by geppy1 on
