Quality bass?
brussell
Whats everyone's opinion on box designs for quality bass. I'm not concerned about being loud. I want to be able to go low (classical music) but have clean, quality bass. My choice is Single 12 Kicker Solo-Baric in a sealed box, circa, 1998 or 2-12 JL Audio in a slot loaded box, circa 1999. My brother wants to trade the JL for the Kicker. The JL won't fit in his jeep but will in my landcruiser.
By the way, all my other speakers, including home are polks!
Thanks,
Brad
Thanks,
Brad
Post edited by brussell on
Sealed boxes will give you better SQ 99.999% of the time.Patience... patience...
Screw patience... Crank the volume and floor it you panzie. -
I' m not a JL fan..I'd run MOMO before JL..or kicker..just my 2cents...if ya want to know why..I can go into detail if you like :
i thinki repled to this one before --- take the kicker and call it a day.
JL by far cannot compare to kicker solo's.The Artist formerly known as PoweredByDodge
