Surge protector for Cinenova AMP
sabotg
sabotg Posts: 126
edited August 2007 in Electronics
I need to get a surge protector for my Cinenova amp but I need to make sure that it isn't a power conditioner also. The cinenova has a built in power conditioner (according the the manual) and adding a conditioner can affect performance. Any reccomendations? I don't want anything too crazy but would like to protect the AMP from power spikes etc...
Post edited by sabotg on
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited August 2007
    I used the Shunyata Guardians with terrific results.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • sabotg
    sabotg Posts: 126
    edited August 2007
    It looks like these are also power conditioners though. You used one with your Cinenova without issues? Plus they seem a little pricy.
  • Systems
    Systems Posts: 14,872
    edited August 2007
    I would suggest something like the surge suppressors built into duplex wall plates that just replace the wall plate on a standard AC outlet.
    They contain 3 MOV's for protection but have minimal filtering(usual a single capacitor from line to neutral) so it will not limit the current available to your Cinenova.Leviton also makes a complete duplex receptical with built in surge suppressors.
    Testing
    Testing
    Testing
  • okiepolkie
    okiepolkie Posts: 2,258
    edited August 2007
    Your amp is pricey too, and it deserves the cleanest, un-impeded electricity you can give it. They might be expensive, but they are worth the money. If you look to go used, try to get a Hydra or Guardian that was made within the last year. There were some moderate revisions done just before that, and the current Guardians are on par with the Hydras 2 years ago.
    Tschüss
    Zach
  • Systems
    edited August 2007
    The problem with using power conditioners on large power amps is they may not be able to supply enough current.Therefore it restricts the amps ability to reach its maximum power levels.
    There are some power conditioners such as the massive Taurus units that will be fine but they are expensive.
    Testing
    Testing
    Testing
  • okiepolkie
    edited August 2007
    GV#27 wrote: »
    That is the reason the Shunyata pieces are so expensive. They don't limit the current flowing through them. That is why so many people use them on high current amplifiers and subwoofers.
    Tschüss
    Zach
  • Gaara
    Gaara Posts: 2,415
    edited August 2007
    What about something like a high current ultimate outlet from PS Audio?
    I personally preferred the sound with my Cinenova plugged directly into a dedicated line as opposed to running through a Monster line conditioner. When I got my BPT balanced power unit I much preferred the Cinenova being hooked into the BPT. Never really gave to much thought to surges.
    Jared
  • wingnut4772
    edited August 2007
    sabotg wrote: »
    No issues at all . Worked very well.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Systems
    edited August 2007
    Gaara I checked out your rigs and you have some nice stuff.I've never heard of the Rawstone units would you by chance have a link for them.Im in the process of building an LM3785 based gainclone kit for my PC speakers.
    Thanks.
    Testing
    Testing
    Testing
  • Gaara
    Gaara Posts: 2,415
    edited August 2007
    GV,
    sorry no link. Tim Rawson sells most of his stuff through Agon and custom orders from customers. He has made amps using the 3785 chip, 3886, bpa200, bpa300, ska amps, hypex, Aleph...probably more.
    I have had him make me a 3886 gainclone and more recently a BPA200 4ch amp.
  • Systems
    edited August 2007
    Gaara wrote: »
    GV,
    Ah interesting,thanks for the reply.
    I really like the chassis he used and wish I could source one or two.:) If I like the the results of my Gainclone I may build a 4 ch version to drive the side/rear surrounds in my HT.The Aleph clones are also very tempting.
    Testing
    Testing
    Testing
