Help! What does this mean?
Serendipity
Serendipity Posts: 6,975
edited August 2007 in The Clubhouse
So today I'm watching a DVD on my HT and all of a sudden I hear a loud BEEP BEEP BEEP and then everything turns off.
I look at my APC power unit and on the front, the "AVR Trim" LED is lit. I consult the manual for the unit and it states under the troubleshooting section:
"The Automatic Voltage Regulator (AVR) Trim LED comes on, indicating the unit is compensating for a high voltage level."
What could this mean and what's wrong?
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
  • dkg999
    dkg999 Posts: 5,647
    edited August 2007
    My first guess is that you had a voltage spike.
    DKG999
  • Serendipity
    edited August 2007
    dkg999 wrote: »
    Could possibly be, but the warning light is still on. If it were a spike wouldn't the light be on for a short period of time?
    treitz3 Posts: 19,952
    edited August 2007
    Is there a reset button?
  • Serendipity
    edited August 2007
    treitz3 wrote: »
    No.
    It's not like some power strips that have a reset button on the side.
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited August 2007
    it means its gonna blow!!! DUCK! *ducks*
    Kidding, APC brand? From my experience with any APC brand unit any warning light 80% of the time leads back to the backup battery within the unit. Check the voltage on the battery.
  • Serendipity
    edited August 2007
    Checked the battery. It seems to be normal, 13.5V, and still holds a charge.
  • wallstreet
    wallstreet Posts: 1,405
    edited August 2007
    Git rid of it and listen in oblivious happiness.
  • Serendipity
    edited August 2007
    wallstreet wrote: »
    I don't think so...
    Besides, I like power conditioning/surge protection for all my gear.
  • BaggedLancer
    edited August 2007
    Have you checked the voltage coming out of the wall?
  • Serendipity
    edited August 2007
    131V, with nothing plugged in to that circuit...
    127-129V, with the projector and HT plugged in.
  • Serendipity
    edited August 2007
    Is this a problem? Should I call the utility company?
