Help! What does this mean?
edited August 2007 in The Clubhouse
So today I'm watching a DVD on my HT and all of a sudden I hear a loud BEEP BEEP BEEP and then everything turns off.
I look at my APC power unit and on the front, the "AVR Trim" LED is lit. I consult the manual for the unit and it states under the troubleshooting section:
"The Automatic Voltage Regulator (AVR) Trim LED comes on, indicating the unit is compensating for a high voltage level."
What could this mean and what's wrong?
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
Welcome!
    edited August 2007
    My first guess is that you had a voltage spike.
    DKG999
    edited August 2007
    dkg999 wrote: »
    Could possibly be, but the warning light is still on. If it were a spike wouldn't the light be on for a short period of time?
    edited August 2007
    Is there a reset button?
    edited August 2007
    treitz3 wrote: »
    No.
    It's not like some power strips that have a reset button on the side.
    edited August 2007
    it means its gonna blow!!! DUCK! *ducks*
    Kidding, APC brand? From my experience with any APC brand unit any warning light 80% of the time leads back to the backup battery within the unit. Check the voltage on the battery.
    edited August 2007
    Checked the battery. It seems to be normal, 13.5V, and still holds a charge.
    edited August 2007
    Git rid of it and listen in oblivious happiness.
    edited August 2007
    wallstreet wrote: »
    I don't think so...
    Besides, I like power conditioning/surge protection for all my gear.
    edited August 2007
    Have you checked the voltage coming out of the wall?
    edited August 2007
    131V, with nothing plugged in to that circuit...
    127-129V, with the projector and HT plugged in.
    edited August 2007
    Is this a problem? Should I call the utility company?
Welcome!
Welcome!
