MOMO's
djgurp23
djgurp23 Posts: 4
edited August 2007 in Car Audio & Electronics
I just got the components and 6x9's installed and wow do they sound good :)
I have them running to the kicker zx350.4 amp. Only thing that bothers me is the bass isnt very good. That's not going to be a problem in a couple days because I am going to get my 12" CVX installed. But for now I would still like some bass out of the speakers. And also I ran new speaker wire from the hu to the amp in the trunk, but just used the factory wire from the components to the hu. Should I upgrade the factory wiring, and will it really make that big of a difference in sound quality and performance? Thanks guys :)
Post edited by djgurp23 on
  • Greg Peters
    Greg Peters Posts: 605
    edited August 2007
    Let them break in for a bit, then give the midbass some scrutiny. Every Polk speaker I've purchased sounded better after some break-in time ;).
    Report back on how it goes.
  • eloplayspolo
    eloplayspolo Posts: 1,117
    edited August 2007
    they are mid range woofers, u wont get deep bass from them, most people with components have subs.
    As far as wiring goes, heres how i see it, and this is how it was explained to me, this goes pretty much for any A/V equipment.
    U spend 300 bucks on item A, which in your case is a speaker, U spend 500 bucks on item B, which in your case is an amp, Item C (your wires) brings those items together, why cut yourself short in between 2 high quality items.
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited August 2007
    Give the speakers suspension a little time to break in, as Greg has said, and you will notice a little more low end from them.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • MacLeod
    MacLeod Posts: 14,358
    edited August 2007
    It depends on how far the wire is running. Unless youre running 150 watts per channel a foot or 2 of factory wiring isnt going to make a difference. But if its about 5 foot like it would be from the hu to the speakers, that might build up enough resistance to make a difference. It wont be the end of the world if you leave it like this but if youre wanting the best out of your system then replace the OEM crap with proper size wire.
