Floor Speaker Scratchy
edited August 2007 in Speakers
I have a Polk home audio floor speaker and after I moved, the speaker went from normal to scratchy. I have a strong feeling that this is was a result of my bad movers and not from over use. I tried new cables, didn't work. I pressed around the speaker, nothing changed. What could be the problem and how do I fix it???
Post edited by jestrada6 on
Welcome!
    edited August 2007
    what model of speaker is it?
    PolkFest 2012, who's going>?
    edited August 2007
    Not sure...had it about 6 years. It's a floor model with only the speaker portion under the top grille. It's black, wood all around on platform. Sorry...
    edited August 2007
    edited August 2007
    is it one of the blue mid bass drivers that is scratchy? push on the blue part gently to it goes in then gently let it out. do that a few times.. if it's scratchy. i think it's fried.
    if it's not scratchy.. then it may be your crossover.. in that case. call Polk audio up and order a new one. i did. and solved my problemo
    edited August 2007
    if you call Polk and order any part(s) tell them up front you are a Club Polk member.. and they will give you faster shipping and a better price.
    edited August 2007
    Did it several times and its still scratchy. Can a speaker get fried in a move? What can I do to fix it. Thanks for the help...
    edited August 2007
    Is this "scratchy" sound emitted from the tweeter, or one of the woofers?
    edited August 2007
    From both of the woofers.
    edited August 2007
    And on the woofers that are making the "scratchy" sound, when you press on the cones and release, do you feel any friction whatsoever, or do they push back gently to there original position?
    Try this with all woofers with the rig powered down.
    edited August 2007
    There is definitely friction when I press on them...power is off.
    edited August 2007
    On all of them, or just one?
    edited August 2007
    All of them. (2)
    edited August 2007
    It's almost like there's something in the way...
    edited August 2007
    Sorry, not familiar with your speakers. It sounds to me like you have fried the coils within the woofers themselves. There should be absolutely NO friction whatsoever.
    edited August 2007
    This happened after I moved. I think the box got dropped since the speaker worked before we moved. How do I take the speaker out of the speaker box? My allen wrenches don't fit...
    edited August 2007
    You may want to remove the woofers and check to see if something internally within the speaker has lodged itself in the path of the cone, but I seriously doubt it if it is on both woofers.
    Call Polk, as DB suggested, mention that you are a Polk member and experience some great customer service.
    edited August 2007
    Thanks for the help!
    edited August 2007
    You will have to get the correct sized allen wrench. My speak's look like they are 4-5mm, but I'm not positive. Maybe someone else can chime in on that.
    Most Dollar stores carry cheap sets that you can remove them with, if not HD or any hardware store will have them.
    edited August 2007
    Make sure you lay the speaker down...
    When you remove the baffle that holds the drivers in - they are pressure fitted in. Absolutely no screws. So if you have it standing up - more issues will occur.
    Common sense, but ya know haha
    They must of dropped that speaker REALLY hard to dislodge two voice coils, wow...
    edited August 2007
    The magnets have shifted, time for new drivers.
    edited August 2007
    bummer.. but I think he's right.. as usual :p;)
    does polk make a replacement driver? didn't they run out of the blue ones? Either way.. call Polk customer service and see what they have to say.
    good luck.
    edited August 2007
    wow, both drivers? were the movers using it as a tackling dummy?!?!
    those speakers are definitly worth getting the 2 new drivers, order em up.
    I would complain like hell to the moving company,, but it probably wont get anywhere, cant hurt to ask though, if you only claim the cost of the drivers as the damage, they might reimburse you just to shut you up if your annoying enough.
    either way, sad fact is there are always casualties when you move.
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
    edited August 2007
    edited August 2007
    And what is it you want to sell?
    edited August 2007
    ////\\\\ only ten more to go.
Welcome!
Welcome!
