SRS 1.2 Retrofit now get aire release
gdsk39a
Replaced all woofers and tweeters in my SRS 1.2's. They sound great. I noticed when I push on the passive radiator air can be heard coming out of the woofer area of some of the woofers. Is that normal? Of course I tried this with no music playing. I don't recal having heard that air noise before I did the replacement of the drivers and tweeters
I will tell you though that the rubber material not being cut where the holes are on the woofers is totally annoying. I hope I haven't damaged the rubber material when I tightned the screws as I noticed material would get caught in the screw and deform the rubber material.
Anyway anyone hear the air noise when pushing on the passive radiator?
Post edited by gdsk39a on
There is a thread or two about this and yes, it's most likely the rubber "tabs" getting in the way as it deforms the rubber surround on the drivers when you tighten them down. If you feel the drivers are ruined then contact Ken at Polk and he'll take care of it.
At this point I'd remove the drivers & carefully cut the offending excess rubber out of the screw holes and reinstall each driver to see if they are normal. If not, Polk will take care of it for you. Why the over lapping rubber isn't removed during manufacturing, I don't know. This has only been an issue recently.
Good luck
Try to do a search for the two other threads about this exact issue."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
http://www.polkaudio.com/forums/showthread.php?t=54688
http://www.polkaudio.com/forums/showpost.php?p=658148&postcount=3
Did you reuse the gasket material from the old drivers?Political Correctness'.........defined
President of Club Polk -
I agree, Its not like its cut wrong but placed on the driver wrong.
Make sure if you do this mod to the driver, you use a very sharp, new blade. If you pull the rubber while cutting, the driver is ruined.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek:
