SRS 1.2 Retrofit now get aire release
gdsk39a
gdsk39a Posts: 28
edited August 2007 in Vintage Speakers
Replaced all woofers and tweeters in my SRS 1.2's. They sound great. I noticed when I push on the passive radiator air can be heard coming out of the woofer area of some of the woofers. Is that normal? Of course I tried this with no music playing. I don't recal having heard that air noise before I did the replacement of the drivers and tweeters
I will tell you though that the rubber material not being cut where the holes are on the woofers is totally annoying. I hope I haven't damaged the rubber material when I tightned the screws as I noticed material would get caught in the screw and deform the rubber material.
Anyway anyone hear the air noise when pushing on the passive radiator?
Post edited by gdsk39a on
    heiney9 Posts: 25,612
    edited August 2007
    There is a thread or two about this and yes, it's most likely the rubber "tabs" getting in the way as it deforms the rubber surround on the drivers when you tighten them down. If you feel the drivers are ruined then contact Ken at Polk and he'll take care of it.
    At this point I'd remove the drivers & carefully cut the offending excess rubber out of the screw holes and reinstall each driver to see if they are normal. If not, Polk will take care of it for you. Why the over lapping rubber isn't removed during manufacturing, I don't know. This has only been an issue recently.
    Good luck
    Try to do a search for the two other threads about this exact issue.
    edited August 2007
    F1nut Posts: 52,244
    edited August 2007
    Did you reuse the gasket material from the old drivers?
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    heiney9 wrote: »
    I agree, Its not like its cut wrong but placed on the driver wrong.
    Make sure if you do this mod to the driver, you use a very sharp, new blade. If you pull the rubber while cutting, the driver is ruined.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
