Crown Amps
Systems
Systems Posts: 14,873
edited August 2007 in Electronics
Anyone have any words on Crown amps. I've been checking out their page and they look like they give big affordable power. Any help would be appreciated.
I like the 400+ watt per channel models but they have a ton of different models. I would be looking to drive my rti12's with them:
XLS:
http://www.crownaudio.com/amp_htm/xls.htm
CTS:
http://www.crownaudio.com/amp_htm/cts.htm
CDI:
http://www.crownaudio.com/amp_htm/cdi.htm
Testing
Testing
Testing
  • Systems
    edited August 2007
    These are all pro amps and are very powerful but will likely fall well short of the refinement you would get from a good audiophile amp.But they would be great subwoofer amps.
    Testing
    Testing
    Testing
    VR3 Posts: 29,427
    edited August 2007
    Great subwoofer amps.
    Way to bright and nasty sounding for main speakers in a house setup.
    Great for cut through, ear piercing highs for a pro audio rig --- allows for massive bass and alot of clarity. Just really*** hard to listen to for anything else.
    Pro Audio amps, insert brand here, you will get the above reply. They are what they are. They are POWER, absolutely no reserve, no current, made to run full volume, with loads and loads of power. They are affordable high power amps. But they are no where close to fidelity.
    However, I love my XTi1000 for my subwoofers. Absolutely phenominal sounding subwoofer amp with alooot of features. Plugged it up to my RT55 I have laying around and left the room in a hurry.
    heiney9 Posts: 25,432
    edited August 2007
    It's a general audiophile consensous that "pro" gear while giving pretty good bang for the buck just doesn't sound as good and consumer home audio. As has been stated they maek great subwoofer amps but if you are looking for a really good 2ch system, IMO "pro" gear is not the way to go.
    Try it out and see if it works for you.
  • Systems
    edited August 2007
    I just can’t afford the HT amps I see at that kind of power right now. Maybe I’ll just buy 2 more Outlaw monoblocks and biamp the Rti12's with 4 total.
    Thanks for the good advice!
    Testing
    Testing
    Testing
    VR3 Posts: 29,427
    edited August 2007
    Why on earth do you need 400 watts of power? lol
  • Serendipity
    Serendipity Posts: 6,975
    edited August 2007
    +1
    They are great for subwoofers in an HT environment. In fact, the local cinemas in my area mostly use Crown XTi or QSC PLX amps.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2007
    I agree with all the above. If you need more power get the Outlaws.
  • Spacedeckman
    Spacedeckman Posts: 96
    edited August 2007
    They will shave your ears clean off.
    Mark
    System:
    VPI Scout/Benz Ace
    Sutherland PH2000
    Arcam CD72
    Yamaha DVD-CX1 (primarily for CD..26 lbs, all BB D/A)
    Audioprism Mantissa w/Reference PS
    Parasound HCA750 (temporary)
    Audiovector M1 Signatures
    Kimber 4TC x 2
    mhardy6647 Posts: 35,006
    edited August 2007
  • lightman1
    lightman1 Posts: 10,796
    edited August 2007
    Take a look at the mid to late '70 D series amplifiers. They are a bit harsh in 1.5k an up if you use them full range, but they have massive amounts of reserve power for low end (mono per sub in a bi amp). I back heiney9's statement on the new amps. Great power,no range.
    I've felt a Crown D-150,in mono, send 16Hz without failing, to an 18" Gauss in a tuned 14cuft cabinet. But made a pair Celestions books sound like ****. Take it from there.
    Russ
