Amp for LSis ?
bykes
bykes Posts: 132
edited August 2007 in Electronics
Looking for recommendations on an amp for my future LSi9s, LSiC and LSiFX system. Not looking to spend a ton of money, but just something that will do the job at a good price. Something less than $1K
Thanks.
Post edited by bykes on
  • engtaz
    engtaz Posts: 7,669
    edited August 2007
    http://www.polkaudio.com/forums/showthread.php?t=56009
    These for your front 3 would be unbelievable.
    you won't have to worry about upgrade itus.
    engtaz
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2007
    There are tons of threads on this forum regarding this situation. However I suggest you raise the amount you want to spend.
    The LSI's perform best with lots of power. in the range of 200wpc & up. Even used, that costs more than $1K.
    If you are not willing to spend the amount needed to properly drive the LSI's without risking them or your receiver, than look for another speaker.
    Or you can snatch those Adcoms! WOW!
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited August 2007
    The NAD gear will work for you. I enjoyed the 2600/2700 power envelope series, they can be had used on Audiogon in the 250-450 range.
    Its just one option of many, parasound would be another company to look at.
    RT1
